question about motor build
Old Sep 25, 2009 | 08:37 PM
blackccoupe's Avatar
Default question about motor build
i'm planning on just doing pistons and bearings do i need to replace the oil pump miles are high and what is the best way to press the stock piston pins out ?
Old Sep 25, 2009 | 11:54 PM
civic_r87111's Avatar
Default Re: question about motor build
I know some ppl have done it but if ur going into the engine I would just replace the rods as well with some forged ones. I haven't had any luck on stock rods, just my 2 cents.
Old Sep 26, 2009 | 07:04 AM
NonovUrbizniz's Avatar
Loved
I would definately recomend doing the oil pump now... if it goes all your work was a waste.
As fars pistons only. I'd only do that if you're not planning on making over 200 or so hp.
You should look into the FJT/Vitara combination but I think they're currently out of stock.
If you choose not to do that then the best way to press out the piston pins is to use a press... if you don't have one you can jerry rig some sockets and a vice to do the same thing but it's definately riskier as far as damaging the rods if you plan on re-using them.
Old Sep 26, 2009 | 07:41 AM
srmofo's Avatar
take your rods and new pistons to a machine shop and get them done right, those babies are in their tight and I believe your supposed to put some heat to them. IMHO I would just replace them, rods are one of the cheapest parts on a rebuild anymore. Do the oil pump you wont regret it, even if it is just for peace of mind
Old Sep 26, 2009 | 07:42 AM
motor is a integra ls only goiong for 250 horse
Old Sep 28, 2009 | 09:57 AM
If ur planing on staying all motor than u could reuse ur stock rods but u will b pushing the limit. I agree with srmofo, a machine shop would b ur best bet and most of them only charge $30-40 anyway but like I said b4 tho some forged rods r the way 2 go and u can put it all together urself too.
willyb92
19
Jun 4, 2010 06:27 PM
Project_SOHC_EX
Dec 19, 2009 11:58 AM
the.hamburglar
Sep 30, 2005 07:07 AM
Alstare
Nov 25, 2003 09:02 PM
BlueSi2k
Jul 31, 2002 09:14 PM
