a really good check valve
Old Oct 9, 2005 | 04:14 PM
ham's Avatar
ham
Default a really good check valve
whats a really good check valve that will flow for pcv vacuum while not in boost and while in boost it will block reverse flow?
i have my black box running to my compressor and i want to run the valve cover barb to the charge pipe but not unless i have a very good check valve on it. right now its venting and stinks when i have the heat on
Old Oct 9, 2005 | 04:18 PM
thermal's Avatar
Use a brake booster check valve
Old Oct 9, 2005 | 04:26 PM
ham's Avatar
ham
Default Re: (thermal)
how do those home depot in line catch cans work while having pressure in the wrong direction?
Old Oct 9, 2005 | 05:17 PM
KeyserSoze's Avatar
Default Re: a really good check valve (ham)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ham &raquo;</TD></TR><TR><TD CLASS="quote">whats a really good check valve that will flow for pcv vacuum while not in boost and while in boost it will block reverse flow?</TD></TR></TABLE>
http://www.swagelok.com/PRODUC...%3D18
REALLY nice check vavle, but I'm sure quite expensive. I don't know how expensive, because we have an account with them @ my work, so that stuff is free 99.
Old Oct 9, 2005 | 05:36 PM
ham's Avatar
ham
Default Re: a really good check valve (KeyserSoze)
where are the prices!
Old Oct 9, 2005 | 06:54 PM
beepy's Avatar
Go to the well/sewage part of Home Depot and get a priming valve. I have a 1" priming valve on my BOV so that my MAF doesn't freak out at idle. Smaller ones would work wonders on the PCV system.
FYI, the oil seperators DON'T stop your crankcase from becoming pressurized. They just filter oil vapor out.
Old Oct 9, 2005 | 08:14 PM
ham's Avatar
ham
Default Re: a really good check valve (beepy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy &raquo;</TD></TR><TR><TD CLASS="quote">Go to the well/sewage part of Home Depot and get a priming valve. I have a 1" priming valve on my BOV so that my MAF doesn't freak out at idle. Smaller ones would work wonders on the PCV system.
FYI, the oil seperators DON'T stop your crankcase from becoming pressurized. They just filter oil vapor out.</TD></TR></TABLE>
thank you and i know about the oil separators, i was asking because they only flow one way.
Old Oct 10, 2005 | 03:46 AM
KeyserSoze's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ham &raquo;</TD></TR><TR><TD CLASS="quote">where are the prices!</TD></TR></TABLE>
You would have to call or email them I'm sure.
lurkin' eg
Oct 19, 2008 04:28 AM
londoncivic
May 10, 2008 09:09 PM
vtec.dc2
Apr 26, 2005 07:57 AM
hatchedzex
Jul 18, 2004 05:47 PM
ScrapinSi
Apr 18, 2004 07:29 PM
