Check valve to raise boost? **confused**
If I were to put a check valve in-line, technically, wouldn't that raise my boost level? Because by bleeding off some of the pressure, it would take longer for the wastegate to open...
How many psi would the average aquarium check valve bleed off?
Re: Check valve to raise boost? **confused** (ScrapinSi)
draw a diagram. do you mean putting it inline so that the wastegate doesnt see boost??? or what i dont realy understand.
Landon
Landon
Re: Check valve to raise boost? **confused** (boosted_dc2)
exactly that... tial wastegate... boost source is coming from the compressor... T a check valve in line which would bleed off pressure... similar to the way a check valve bleeds off pressure to the map sensor, right?
Re: Check valve to raise boost? **confused** (jerseykid609)
i always though when useing a check valve you make it so the source doesnt see boost. ie. place it inline, not t'd in.
Landon
Landon
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted_dc2 »</TD></TR><TR><TD CLASS="quote">i always though when useing a check valve you make it so the source doesnt see boost. ie. place it inline, not t'd in.
Landon</TD></TR></TABLE>
uggggggggggg........... soo confused... can somebody draw a diagram?
I took a T and installed it.. Got up 1 psi. Cut the open end of the T off went up another psi... bored out the hole some more, and now i'm at 7.5 psi... HOLY SHNIKES!!! I love boost! Thanks guys!
oh i see, yea that makes sense. i was thinking you were going to try it like #3 and thats why i was confused.
Landon
Landon
