how much boost???
Old Dec 7, 2001 | 10:21 PM
1sick4door's Avatar
Default how much boost???
how much boost can do you think i can handle with my set up i am getting....98 ex motor with crower rods and je psitons...also it is sleeved...greddy turbo kit with intercooler...regulator..fmu..holley pump..96+ fuel injectors...apexi super afc...havent got a boost controller yet(any idea)...how much boost do you think i could handle wiith this setup so far and any idea about how much hp it will be putting out....thanx
Old Dec 7, 2001 | 10:29 PM
Adi Radoncic's Avatar
On Fire!
Default Re: how much boost??? (1sick4door)
**** if its sleeved you should have no problems running 20psi or higher with good tuning.......
Old Dec 8, 2001 | 10:49 AM
ekb18c's Avatar
Default Re: how much boost??? (newgsr)
with your set up i think you only enough fuel for about 10-14 lbs for a little bit. I wouldnt recommend that you stay with that for too long. You will need a bigger fuel pump and some better injectors. Just becuase you have a sleeve block dont mean **** if you dont have the fuel for it. So your sleeves wont crack under higher boost, but your going to denonate if you are going to plan to run more then 14 psi
[Modified by ekb18c, 7:51 PM 12/8/2001]
Old Dec 9, 2001 | 11:54 AM
DA666's Avatar
Default Re: how much boost??? (ekb18c)
id go with like 450's cc injectors, str fuel rail or sumthin, and bosch/aeromotive inline fuel pump and like an aeromitive regulator, to adj psi..but also get a fuel press gauge....and upgrade fuel lines from tank to pump to rail...or however your gonna set it up....but you could run 20+ on that block...all u need is a good fuel set up...or standalone and injectors.
Old Dec 9, 2001 | 11:55 AM
DA666's Avatar
Default Re: how much boost??? (T3T4DA6)
oh yeah ditch the fmu and intank holley
that= leanin out=blown motor, wether its built or not..u need to flow mad fuel for mad boost...c
Old Dec 9, 2001 | 12:02 PM
meanteg's Avatar
New User
What?! you say a Holley intank wont do the job? I got a Holley 255 lph... In my GSR .. it's goog for how much boost?
I heard it was goot for up to 500 HP......
Old Dec 9, 2001 | 03:42 PM
TurboSedan's Avatar
New User
Default Re: how much boost??? (meanteg)
Yeah the intake Holley/Walbro 255lph can flow enough for way more than 20PSI will give you. The FMU I would forget about though. A standalone will be the only way to run 20PSI sucessfully over a period of time longer than one day.
Old Dec 9, 2001 | 04:22 PM
jinxproof99's Avatar
New User
you may be able to take 15 lbs on a small t3/4, but you won't take that off a 62-1. its about hsp and how much your motor can make safely. not about boost.
Old Dec 9, 2001 | 05:38 PM
BlueShadow's Avatar
Default Re: how much boost??? (97CivicFerio)
ditto... and probably 500 or 700cc + injectors but like 97CivicFerio said you will definately want a standalone/Hondata 4B for 15+ PSI
ABK
Engine Management and Tuning
Dec 20, 2008 11:49 AM
Y2KCivicSiR
May 28, 2004 11:28 PM
flip1199
Jul 20, 2003 11:19 AM
93LSivic
Apr 29, 2002 03:35 AM
Tomakit
Dec 10, 2001 10:43 AM
