Readings on A/F guage
Old May 11, 2002 | 06:19 PM
Teg4e's Avatar
Default Readings on A/F guage
Ok, with the baby-steps help from this board I managed to finally get my a/f guage running. Thanks guys!
I'd like to get some comparisons with you guys on the readings I'm getting. I'm still basically stock now; just the cai is on.
Neutral @ Idle: jumps around randomly
Neutral @ highway speeds: no reading
Light or medium throttle: goes between barely lean to rich in a back and forth pattern.
WOT: a couple into the green, rich area.
How do yours compare? and are my readings normal for a stock LS?
Old May 11, 2002 | 06:21 PM
Giuseppe's Avatar
Default Re: Readings on A/F guage (Teg4e)
most guys on this board, am i myself agree, that those units
are just a piece of junk.
only read reason to have one is to read rich at WOT under boost..
but yeah mine is a disco ball of fire too
Old May 11, 2002 | 06:58 PM
shadowdawn's Avatar
I can help you with this one...
1. Autometer a/f gauge is 90% piece of ****, worthless...
2. My readings are the same
however ONE redeeming factor is recently for no reason around 3-4000rpm I was hitting dead lean while in boost... thought it was odd, let this happen a few more times to make sure it wasn't the gauge being random. I then actually tuned my AFC for the first time and bumped it up 10% at 3000 and 7% at 4000rpm under hi and lo throttles... now it reads full into the rich all the time in boost.... I suppose I got some use out of the thing.
Old May 11, 2002 | 08:10 PM
D-Man's Avatar
Neutral @ Idle: jumps around randomly-normal
Neutral @ highway speeds: no reading-good,its going full lean at cruise speed,like it should
Light or medium throttle: goes between barely lean to rich in a back and forth pattern-good,coming off of no reading full lean as u give it more gas
WOT: a couple into the green, rich area.-should be steady at wot,looks good
compares about the same as mine,The Autometer is good to show what voltage your ECU is getting from the O2 and its good to see if your O2 is working right,most people dont understand why it goes back and forth,so they call it a disco ball hahaha...no nothings
Old May 12, 2002 | 03:11 AM
BlueShadow's Avatar
Default Re: Readings on A/F guage (Giuseppe)
I thought that was normal behavior? at idle or non-WOT you will cycle back-and-forth between lean and rich, but when you go WOT you'll go full rich and stay there.
when in open loop the car is taking sensor inputs and is using that to determine the amount of fuel. but when you go WOT it switches to closed loop operations and the amount of fuel is determined by a fuel map sotred in the ECU?
someone correct me if I'm wrong.
EX-T
Mar 19, 2011 01:09 PM
DarkBB4
Sep 4, 2004 03:27 PM
tianporn
Jun 29, 2004 04:39 AM
CWBETB
May 12, 2003 04:30 AM
uneekcrx
Jun 3, 2002 04:50 AM
