egt temps on the interstate..?
Old Jun 2, 2002 | 10:18 AM
uneekcrx's Avatar
Default egt temps on the interstate..?
how hot are you guys running on the interstate...?around 80mph my guage is reading around 1400-1425 at 80mph is this normal? my probe is located in the manifold and under boost i'm at 1350 so that part is ok....i'm gonna try to bump up my static fuel pressure to see if that helps some..
Old Jun 2, 2002 | 10:20 AM
GruvyTune's Avatar
New User
Default Re: egt temps on the interstate..? (uneekcrx)
its normal, I run a little over 800C just cruising at light throttle in closed loop mode.
Old Jun 2, 2002 | 10:31 AM
Xerxes's Avatar
New User
yeah mine are the same.. i consistently get the hottest temps when i'm cruising on the freeway at 75+mph... seems the higher my cruising rpm, the higher the EGTs, but i know i've got nothing to worry about because the air/fuel gauge is bouncing back and forth just like stock
-Xerxes
Old Jun 2, 2002 | 10:40 AM
shadowdawn's Avatar
Default Re: egt temps on the interstate..? (Xerxes)
weird I get 700 and change on the freeway, but my max egt temps are in the area of 850c.... this happened reving 3rd on the highway to 110, not even WOT, just slowly pushing it up.... oh well.
Old Jun 2, 2002 | 11:32 AM
dustin's Avatar
Default Re: egt temps on the interstate..? (shadowdawn)
I see 700C on the freeway @ 80mph
Old Jun 2, 2002 | 05:53 PM
LEON's Avatar
Default Re: egt temps on the interstate..? (dustin)
I see 700 C on the highway at 75mph (but very dynamic with load). I'm seeing ~820 C at WOT.
Old Jun 2, 2002 | 06:58 PM
JMinSi2000's Avatar
Default Re: egt temps on the interstate..? (LEON)
I'm at 1400F on the freeway goin 80. Thats untuned hondata though.
Old Jun 3, 2002 | 02:52 AM
modvp's Avatar
Default Re: egt temps on the interstate..? (JMinSi2000)
1375-1400 F @ 80 mph. Probe is in #4. Under boost (6 psi) , it drops to 1300 F.
Old Jun 3, 2002 | 04:50 AM
DSF's Avatar
DSF
Default Re: egt temps on the interstate..? (modvp)
According to planet alignment I see anywhere from 1250-1350 cruising on the highway. The same or less at WOT in boost.
asnboi_512
Oct 6, 2004 09:27 AM
tianporn
Jun 29, 2004 04:39 AM
RedTegLS
Dec 28, 2003 11:30 PM
flat-blk-HB
Jun 9, 2002 01:56 PM
slewis
Nov 4, 2001 02:32 PM
