rc 720 @45 psi
Old Feb 14, 2006 | 07:14 PM
22psicrx's Avatar
Default rc 720 @45 psi
rc 720 cc at 45 psi of pressure whats max hp one could make?400-450whp
setup t3-60-1 .63 built sleeved b16 pistons rod valves 68mm tb victor x hondata 255 warlboro. run 15 psi all day but I'm afraid to turn up the boost because of the injectors. It is in a 1988 crx.
Should I get 1000cc? thats a lot for an injector 200 a piece.
Also, 720 and race gas?
Old Feb 14, 2006 | 07:38 PM
Mase's Avatar
Default Re: rc 720 @45 psi (22psicrx)
720's should be good for more than 450 whp
Old Feb 14, 2006 | 07:49 PM
havok hybrid's Avatar
turn the fuel psi to 60 . and you are good for 450 .
Old Feb 14, 2006 | 08:02 PM
turbosijuice's Avatar
Default Re: rc 720 @45 psi (havok hybrid)
i think you could get close to 500 with those i have 780s that are rated for 550 so 500 shouldnt be a problem
Old Feb 14, 2006 | 08:10 PM
integra_gsr98's Avatar
Default Re: rc 720 @45 psi (turbosijuice)
Why the hell would you run 60 psi of fuel pressure?
I ran out of fuel making 558 whp on 720cc injectors at a base FP of 42.
Old Feb 14, 2006 | 08:11 PM
komat's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 22psicrx &raquo;</TD></TR><TR><TD CLASS="quote">Should I get 1000cc? thats a lot for an injector 200 a piece.
its about 320 shipped for a brand new set of 4 injectors
not 200 per one
Old Feb 14, 2006 | 08:15 PM
JDMs1eeper's Avatar
750's at 80% duty cycle should support 430hp @ 43.5psi.
But your FPR is a 1:1 so it'll increase pressure while boosting to get to your goal. Should easily support 450
Old Feb 14, 2006 | 08:17 PM
JDMs1eeper's Avatar
Default Re: rc 720 @45 psi (integra_gsr98)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra_gsr98 &raquo;</TD></TR><TR><TD CLASS="quote">Why the hell would you run 60 psi of fuel pressure?
I ran out of fuel making 558 whp on 720cc injectors at a base FP of 42.</TD></TR></TABLE>
their is nothing wrong w/ raising fuel pressure to 60psi, if you ask me.
Currently I'm tuned on 60psi w/ my 1,000's.
Old Feb 15, 2006 | 03:01 AM
22psicrx's Avatar
Default Re: rc 720 @45 psi (JDMs1eeper)
So do you think I could max the injector at 80% before I need race gas or a new set of injectors. comp ratio is 9.0.What about 15 degrees of timming at fill boost or should it be less for a starting point.
Old Feb 15, 2006 | 05:13 AM
JDMs1eeper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 22psicrx &raquo;</TD></TR><TR><TD CLASS="quote">So do you think I could max the injector at 80% before I need race gas or a new set of injectors. comp ratio is 9.0.What about 15 degrees of timming at fill boost or should it be less for a starting point.</TD></TR></TABLE>
The first question was do'able. Now you want us to preform magic by predicting exactly how your engine will react to your fuel at your preticular part of your city Your second question can be found w/ dyno tunning, not on HT.
Old Feb 15, 2006 | 02:46 PM
22psicrx's Avatar
I did some logs. Duty cycle at 77% at 18psi. Should I now change to 880cc or higher. Just asking questions. The car has been running perfect for 9 months just think with the turbo and biult motor that I'm not getting my moneys worth. Witch means if the turbo could make more and the motor can should change the injectors for safety sake.
Old Feb 15, 2006 | 11:22 PM
turbosnatch's Avatar
http://www.rceng.com/technical.htm
that should help
uscivicmc
Aug 14, 2011 09:11 AM
SpeedingHatch
Dec 31, 2005 02:41 PM
onefstek
May 27, 2005 10:22 AM
The DX Rex
Dec 28, 2004 07:25 PM
platinum00
May 15, 2004 07:14 PM
