fuel injector help
Old Nov 30, 2001 | 06:54 PM
Farnsrocket's Avatar
Default fuel injector help
I bought some mildly used RC 310cc injectors and they do not seem to fit my car like the stock ones do. The guy had them in a Type R (B18C5) engine and I have a 95 GSR with Skunk2 manifold so it should be the same set up. The o-ring seals that plug into the fuel rail are the same and plug in fine. The bottom seal, where the injector plugs into the manifold does not fit on the RC injector and the injector just sits on top of this seal. It does not let the injector sit into the manifold as far, by about 1/4" or more and it just does not seem like a good fit justresting on top of this seal. Do RC injectors come with different seals? I have a picture but am not sure how to send it. Thanks for any help you guys can give me.
Old Nov 30, 2001 | 10:44 PM
TurboTegB18c's Avatar
Default Re: fuel injector help (Farnsrocket)
The RC injectors will not fit like the stock ones do. The stock ones go all the way down the rubber seal where as the RC injectors rest on top of the seal. I know that it looks kind of strange but that's how ther're made. Hope that helps.
Old Dec 1, 2001 | 06:04 AM
Default Re: fuel injector help (TurboD16Z6)
Thanks, I was freakin out. I think I am going to have to add some spacers to make the fuel rail fit right. Thanks again!
jtracing919
Mar 23, 2006 04:50 AM
S13 slide
Dec 23, 2005 09:19 PM
