Radiator question...
Old Apr 4, 2006 | 06:54 AM
yellowhonda88's Avatar
Default Radiator question...
Hey all, I finally got around to workin on my car again, moved, new job, etc. Here is my delima. Was running a 92 civic radiator but my dp with heat wrap was literally touching the core of the radiator for about 1.5" before it changed directions. Anyway, i have a hole in that radiator (old setup, motor rocked and WG poked it). Then I procceeded to fill the hole with JB weld and it held for about 2 months and then it really decided to leak. It was a temp solution. Here is the deal, I am going to put a new radiator in the car and I am wondering, do you thing that with heat wrap, a 92 civic radiator will still work (with the heatwrap touching the DP turndown off the 4 bolt flange) or should I measure it and have one made that will fit. If so, any brands that would not cost an arm and a leg to have made. Thanks all.
MiracleWhip
Apr 28, 2007 11:38 AM
AVATAR
Jul 7, 2003 03:08 PM
Just Checking In
Apr 11, 2003 05:57 AM
EGh22aEG
Jan 9, 2002 06:37 PM
mikecel79
Jul 24, 2001 10:10 PM
