Race engineering pistons made by wiseco?
Old Oct 16, 2001 | 07:36 PM
dustin's Avatar
Default Race engineering pistons made by wiseco?
Anyone have any info on these pistons?
http://www.raceeng.com/ Click on import, pistons, race eng
They are affordable.. anyone know what they are made of?
Dustin
Old Oct 16, 2001 | 07:45 PM
immortal's Avatar
Banned
Default Re: Race engineering pistons made by wiseco? (dustin)
wiseco makes Endyn pistons as well
Old Oct 16, 2001 | 07:49 PM
TurboInteg95's Avatar
Quote: "They are affordable.. anyone know what they are made of?"
I think they are made of aluminum, HAHA, J/K.
[Modified by TurboInteg95, 8:50 PM 10/16/2001]
Old Oct 16, 2001 | 07:52 PM
dustin's Avatar
Default Re: Race engineering pistons made by wiseco? (TurboInteg95)
Oh really! I was thinking copper! hehe.
I was just wondering about their strength as compared to, say, JE pistons.
Dustin
Old Oct 16, 2001 | 08:39 PM
yeah, I couldnt resist though. Well, I had a set of Wisecos for a toyota motor and I have to say that they were beefy as hell. The guy from wiseco said they are good for over 30 psi. And he was telling me how all the puerto rican guys use them in there 8 second Corinas and corollas. They were seriously beefy, like they almost looked beefier then the set of JE's I had, but then that was for a Honda Motor.
Old Oct 16, 2001 | 08:53 PM
redline's Avatar
how much are they???
Old Oct 16, 2001 | 09:01 PM
ArizonaTurbo's Avatar
They are NON Silicon Forged Pistons! We recently put them in my buddy's 1998 Nissan Sentra SE (SR20DE) with the stock rods. It made 363 hp & 325 ft/lb to the wheels @ 19 psi! They are 9.0:1 CR Pistons! He just ran an 11.9 @ 119 mph this weekend here in AZ at the IDRC event! That was with a 2600 lb car with full interior! Great pistons for the money!
[Modified by APEXSER, 6:01 AM 10/17/2001]
Old Oct 16, 2001 | 09:07 PM
Default Re: Race engineering pistons made by wiseco? (APEXSER)
APEXSER, are those the raceeng pistons that you are referring to or the Wisecos? or are they the same thing.
Old Oct 16, 2001 | 09:31 PM
dustin's Avatar
Default Re: Race engineering pistons made by wiseco? (redline)
$369/set. I am not sure whether they come with the wrist pins for that price though.
Dustin
Old Oct 16, 2001 | 09:34 PM
hmm, if they come with pins and rings that is an excellent deal,
Old Oct 17, 2001 | 07:15 AM
Race Engineering has Wiseco make pistons to thier specs! ALL Race Engineering Pistons are made by Wiseco, just like Endyn has Wiseco make pistons to their specs also!
Old Oct 17, 2001 | 07:17 AM
Dustin
They come with Wrist Pins, but NOT rings! You can get Race Engineering's Rings for like $79.00 or you can get JE/SRP Rings for under $90.00.
Old Oct 17, 2001 | 07:44 AM
dustin's Avatar
Hmm I'd rather just use honda rings.
Dustin
Old Oct 17, 2001 | 07:54 AM
rtype11's Avatar
They can make you pistons in just about any alloy you want on custom work and copy Je or whatever you want and still are cheap, they produce around here to and the wait isnt that bad either, also Ross pistons have been selling up here like mad recently they are pretty close to bullit proof.
Old Oct 17, 2001 | 08:11 AM
Dustin
They will only work if you buy aftermarket stock bore pistons, which I would NOT recommend! When rebuilding a motor you should at least over bore .5mm (.020"). Leaving a motor stock bore will cause loose piston-wall tolerances causing excessive blowbye through the rings.
Old Oct 17, 2001 | 03:34 PM
dustin's Avatar
Dustin
Honda sells overbore rings. If the sleeves are in good shape with almost no wear there is no reason to overbore. A slight hone works fine. It all depends on the mileage of the motor.
Dustin
Old Oct 17, 2001 | 03:56 PM
HX_Guy's Avatar
Arent Honda's rings only .25 over and not .50?
Old Oct 17, 2001 | 04:06 PM
dustin's Avatar
Default Re: Race engineering pistons made by wiseco? (HX_Guy)
Yeah I think they only sell 25 over.
Old Oct 17, 2001 | 04:40 PM
jamal-188's Avatar
Those pistons are that much cheper than JE's are they? So, if I understand you guys correctly, you don't want to get sized pistons that just drop right in? btw I have a 01 GSR, w/10Kmiles
93_db2
Oct 28, 2003 05:54 PM
IloveNewt
Jun 25, 2003 05:40 PM
turbo Si
Jun 28, 2002 12:00 PM
Ray
Nov 10, 2001 12:02 AM
B18CHatch
Oct 24, 2001 03:18 PM
