help, too much boost, wtf?!
Old Mar 6, 2003 | 10:05 AM
austrian type-R's Avatar
Default help, too much boost, wtf?!
I drove my car today after the winter break. The Greddy boost controller is off, so I should see only 0.45 Bar boost (setted wg spring), rigth? But why is it going to 0.9 Bar? Something wrong with my Profec B?
This happens all the time since I have the meng tubular manifold. Is it possible it flows to good for a 35mm tial wg?
What should I do?
Old Mar 6, 2003 | 10:07 AM
WONG FRIED RICE's Avatar
Default Re: help, too much boost, wtf?! (austrian type-R)
did you ever run without the boost controller? if so did it run at .45 bar before? if not do you have the vacuum lines hooked up correctly on the wastegate?
Old Mar 6, 2003 | 10:09 AM
Default Re: help, too much boost, wtf?! (JDMB16ACRX)
yeah, it is all correct. It is after I installed the meng manifold. I saw 0.45 Bar with the DRAG manifold when I had the Profec off.
I never run w/o a boost controller. Will try to disconnect the hose on the wg.
[Modified by austrian type-R, 8:10 PM 3/6/2003]
Old Mar 6, 2003 | 10:11 AM
PM-Performance's Avatar
are you reading it on your gauge? the gauge might be off, mine is .45 and i read like 8
is the boost creeping? or is it just going to .9 bar and holding...or does it feel like it will go even higher if you keep pushing it.
one of the lines needs to be disconnected from the wastegate if you aren't using your boost controller. i forget which one.
[Modified by JDMB16ACRX, 11:12 AM 3/6/2003]
Old Mar 6, 2003 | 10:18 AM
should be the top one if im correct.
Old Mar 6, 2003 | 10:19 AM
no boost crep, it holds the boost. The gauge is not off. The car pulls much to hard if it would be only 0.45 Bar. Yup, it is the top one.
Well, I hate not to adjust boost ........I am safe up to 1.4 Bar.
[Modified by austrian type-R, 8:20 PM 3/6/2003]
Old Mar 6, 2003 | 10:20 AM
if you have two vacuum lines connected to your wastegate...just disconnect one of them...it should solve your problem.
yea..not just any of the two lines...the correct one
[Modified by JDMB16ACRX, 11:23 AM 3/6/2003]
Old Mar 6, 2003 | 10:22 AM
b18bturbo's Avatar
try large wg vacuum source that direct of the manifold to the top port on the wg.
Old Mar 6, 2003 | 10:27 AM
Default Re: help, too much boost, wtf?! (b18bturbo)
MY top of the wg is attached to the boost controler while the lower wg opening is going to the manifold. Should I make that one to the manifold bigger?
[Modified by austrian type-R, 8:28 PM 3/6/2003]
disconnect the top one
Old Mar 6, 2003 | 10:37 AM
i think you should have either or . no ? i thought you disco the bottom one when you put an ebc on and use the bottom when the mbc is used?
BauleyCivic
Jul 11, 2006 07:36 AM
Sketch_hs
Aug 5, 2004 10:10 PM
RedTegLS
Feb 4, 2004 04:22 AM
austrian type-R
Jul 23, 2002 07:17 PM
RedKevin79
May 22, 2002 07:57 AM
