quick Tial wg question
Old Mar 13, 2002 | 04:26 AM
austrian type-R's Avatar
Default quick Tial wg question
The gasket between the exhaust manifold and the wg flanch is leaky. The car sounds like a freakin truck. Is it possible to mount the wg without the gasket, or would it not seal. I´m thinking about it, cause between turbo and manifold is no gasket either.
Or do I have to make a new gasket of some gasket sheet?
Old Mar 13, 2002 | 06:29 AM
RAWB's Avatar
Default Re: quick Tial wg question (austrian type-R)
I took mine out. I also swapped out the hex bolts and just used my Deltagate bolts to connect the wastegate to the exhaust manifold, as well. I couldn't get enough torque on the TIAL bolts to get a good seal. Haven't had a problem since.
Old Mar 13, 2002 | 06:32 AM
rainforest's Avatar
Default Re: quick Tial wg question (integracon)
i used gasket sealer those gaskets can suck on it they are shitty and dont even fit that well.
GWInquisitor14
Sep 25, 2005 11:30 AM
Akalima
Aug 25, 2005 11:07 AM
trbob16a
Feb 5, 2004 05:45 AM
Snafu-Si
Apr 30, 2003 04:37 PM
dragnGSR
May 11, 2002 08:55 AM
