Smokin'
Old Mar 13, 2002 | 06:47 AM
jdmciviceg's Avatar
New User
Default Smokin'
My car is smoking its *** off at idle but only after it warms up. When I first start it there is no smoke at all. Also under boost ot doesn't smoke but when I pull up to a stop lights it smokes so much that it will cover 3 cars around me. I've checked my turbo and there is no play in it. How can I check to see if its the rings or valve guides? Has anyone had this problem before? As soon as I get this fixed I can finish getting my hondata tuned. I went down to dallas and the wideband went out and we had only tuned up to 4500 rpm so I'm stuck limping around until I get this finished and tuned.
Old Mar 13, 2002 | 07:00 AM
ATurboCivic2NV's Avatar
Default Re: Smokin' (jdmciviceg)
you can do a compression test on you cylinders to find if it is your rings, valves or headgasket. as far as your turbo, mine had almost no play at all in the shaft when it was cold and when it got hot i could move it up down side to side, and in and out. when i took it apart it was bad. i have pics. i must remind you in the pics i cleaned it up some. so i looked worse.
http://www.noricers.com/ourcars/core...borebuild.html
Old Mar 13, 2002 | 07:08 AM
bigTom's Avatar
Default Re: Smokin' (ATurboCivic2NV)
i hope u didnt just slap the turbo just back together with new parts! it has to be balanced at some crazy rpm... i forgot what it was right now
Old Mar 13, 2002 | 07:22 AM
jdmciviceg's Avatar
New User
Default Re: Smokin' (Bad Tom)
The turbo is 6 days old. I really hope its not the problem.
Old Mar 13, 2002 | 07:26 AM
the guy that is helping me does this on big trucks and he said nothing about that.
nothing is bent or anything, just warn out.
Old Mar 13, 2002 | 08:00 AM
Doodoo's Avatar
If you have a boost gauge hooked up try troubleshooting from this article. http://www.motor.com/MAGAZINE/Pdf/082001_05.pdf
Hope it works...hope you figur it out.
oranginal
Jul 3, 2009 11:37 AM
93cxhatchsir2
Oct 15, 2008 06:18 PM
Boostinb20!
Sep 10, 2008 01:11 PM
turbo95eg6
Jul 10, 2005 07:22 AM
Terry_shum
May 1, 2004 05:50 PM
