quick spool B18c1
Hi,
I have a friend building a street car..
What turbo would you recommend for a very quick spool B18c1 ?
CR is 9:1
pump gas (95 octane around here)
boost will be around 10 psi
Target HP is about 250 hp
CR is 9:1
just get a Garrett 60trim
i have b18c with 9-1 pistions and w/
log man and garrett 60trim turbo and made 350hp
at 14lbs boost then we made 480 on c16-racegas on 22lbs
spools up quick!!!
spools up quick!!!
yes, that's the exact answer I want actually.
so you say there's no way a b18c1 can react like a Subaru Impreza or Mitsubishi Evo as a daily driver.
After these.. can we say a B18A1 is a better "quick spooler" for daily use ?
well considering the impreza isn't turbocharged but if your talking about the wrx it spools quick but still not that quick, but consider this it is a 2.0 and has a turbo so small that it makes only 5-6 psi by redline. The sti and evo don't spool that quick either but there bigger displacement makes them feel better down low
Th Impreza is in fact turbo'd, not in America.
16g?
i'd say you can but you'll need to do some R&D as few people try this...
you could try and talk to tony...
i'd say bump the cr quite a bit, at least more then 10cr to regain spooltime, should've done a oem parts build, cheaper and more effective and more then strong enough for 250hp!
