quick and simple injector question
Old Oct 24, 2008 | 07:38 PM
mitchell_2kSiR's Avatar
Default quick and simple injector question
for those who know this should be simple. . .
i have a boosted EM1 converted to obd1 currently with 440cc precission injectors(saturated) on an 8psi tune
next spring i want to up the boost, and my 440's are limited almost running at 90% efficiencey
hoping to run about 12 lbs ish of boost what size do you recomend.
so question is. . i want to go with bigger injectors. . do i look for saturated again like my curent 440's are? which i can only find in the 525cc's as saturated also
or do i go with high impadence or low impadence. . i dont have a resistor as mine is an obd2 system stock
what injectors should i use for my future setup. . high or low ????????
i was thiknig just get the 525 precissions and up fuel pressure with my fpr for a 12 psi tune if it will get it out of them
LMK!!!! also are the RC clips the same as precission injector clips?
Old Oct 25, 2008 | 07:00 AM
Default Re: quick and simple injector question (mitchell_2kSiR)
bump
Old Oct 26, 2008 | 08:25 AM
ttt
Old Oct 30, 2008 | 09:29 PM
ANYONE????
Old Oct 31, 2008 | 08:17 AM
BlackT5's Avatar
High impedence = saturated. Stick with those or you'll need to add resistors. There should be many sizes available that will work for you.
Old Oct 31, 2008 | 08:39 AM
Schister66's Avatar
Man U FTW
PSI doesn't tell us anything. You need more fuel when you make more power. What is it making currently?? Give us more info on the setup
Old Oct 31, 2008 | 06:24 PM
Default Re: (Schister66)
Treadstone/Turbonetics B Series turbo kit
turbonetics t3/t4 turbo 57 trim
turbonetics evolution wastegate
turbosmart boost controller
HKS SQV BOV(mint)
treadstone TR8 intrcooler
blox turbo vacuum block
precission 440cc injectors
CP pistons 9.1:1 81.5 mm bore
Eagle H-Bean connecting rods
AEM wideband UEGO
3 inch madnrel cat back exhaust from Kteller (magnaflow 14 inch resonator into a magnaflow muffler)
3 inch pipe from oil pan back to cat back exhaust with a test pipe replacing cat
ACT 6 puck clutch
8psi tune done by Adam(hamburgler)
like i said my 440's are almost at 90% efficiency on crome and i want to make more power. . car hasnt been dyno'd only street tuned but will dyno next spring after bigger injectors
one more question . . are the injector clips for precission and RC the same?
Old Oct 31, 2008 | 09:38 PM
dpetro1's Avatar
Default Re: (mitchell_2kSiR)
if you want to stick with saturated injectors precision makes 650cc, RC makes 750cc and bosch now makes 1000cc. so take your pick.
or go peak and hold and there will be more sizes avail.
Old Nov 1, 2008 | 12:51 PM
Default Re: (dpetro1)
are the injector clips the same between RC and precission? cuz i have the injector clips that fit the precissions right now
Joeski99Si
Nov 14, 2008 10:22 AM
mitchell_2kSiR
Oct 23, 2008 04:58 PM
9hatchman4
May 22, 2006 03:57 PM
X2BOARD
Jul 8, 2004 11:22 AM
B16A1-EF9
Jun 24, 2004 03:32 AM
