Quick Qustion About Chipped ECUs
Old Apr 13, 2007 | 05:27 PM
inspyral's Avatar
Default Quick Qustion About Chipped ECUs
Hey guys,
I had a question about chipped/socketed ECUs. If my ECU is socketed for Hondata(which I'm presently running), would I need to do anything to it to make it compatible with other tuning programs like Crome? Are the resistor/jumper connections specific to Hondata, or can I just pull out my Hondata and run a normal chip/Crome/etc?
Old Apr 13, 2007 | 08:24 PM
93turbo16's Avatar
Default Re: Quick Qustion About Chipped ECUs (inspyral)
With the S200 stuff, you can just take all the hondata stuff out of the ecu and convert it directly over to crome. The S300 would not be compatible with the male socket installed.
Old Apr 13, 2007 | 08:47 PM
mtber's Avatar
Default Re: Quick Qustion About Chipped ECUs (93turbo16)
A better way to describe it would be:
Hondata s100/s200 ecus are all socketed/chipped with a 28pin socket and chip.
They have a 4 pin header which is used for the s100 or s200 system to plugin,
Crome, Neptune, eCtune, Uberdata almost everything besides hondata s300 use a 28 pin socket.
Hondata s300 uses male pins instead of a socket & 4 pin header as 93turbo16 described.
To run a different system besides hondata, simply unplug the s100/s200 unit & install the new eprom chip into the socketed ecu
Old Apr 13, 2007 | 09:06 PM
inspyral's Avatar
Sweet, thanks for the help guys
Old Apr 14, 2007 | 12:45 PM
93turbo16's Avatar
Default Re: Quick Qustion About Chipped ECUs (mtber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">A better way to describe it would be:
Ok Ok, a little more in depth.
EX-T
Feb 1, 2011 09:02 AM
turbodcxbro
Engine Management and Tuning
Jan 9, 2010 11:31 AM
Chrislow
Mar 20, 2005 06:02 PM
aziz93
Aug 16, 2004 08:29 AM
advanracing62
Oct 11, 2002 07:44 AM
