Quick Question (Hose with Plug)
Old Jul 3, 2005 | 08:26 PM
FrOsTwHiTeDC4's Avatar
Default Quick Question (Hose with Plug)
Ok this is my turbo on my 90 Acura Integra. I was wondering what is the hose coming off of the turbo with the screw in the end is and what it does.
Thanks
Albert
Old Jul 3, 2005 | 08:28 PM
Adi Radoncic's Avatar
On Fire!
Default Re: Quick Question (jdmforlife)
Instead of finding the right sized plug to plug the vacum source on that compressor cover someone used a 90deg brass fitting with a hose and a secrew on it to plug it.
Go to the hardware store and look for a 1/8th" npt brass plug.
Old Jul 3, 2005 | 08:29 PM
Default Re: Quick Question (newgsr)
is that bad or does it make a difference?
Old Jul 3, 2005 | 08:30 PM
tony1's Avatar
That's the boost controller, turn it clockwise for more boost!
On Fire!
Its not bad as long as its not leaking air from there..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">That's the boost controller, turn it clockwise for more boost!</TD></TR></TABLE>
ROFLMAO!! Tony your a craaaaaaazy Mallafalla.. hehe
Old Jul 3, 2005 | 08:33 PM
yeah and if i did that my turbo probably would **** up right?
Old Jul 3, 2005 | 08:45 PM
On Fire!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmforlife &raquo;</TD></TR><TR><TD CLASS="quote">yeah and if i did that my turbo probably would **** up right?</TD></TR></TABLE>
Did what?
Old Jul 3, 2005 | 09:29 PM
twisted it like tony said.
Old Jul 4, 2005 | 01:10 AM
inspyral's Avatar
You can use that port for the boost signal to the wastegate or electronic boost controller, or you can get a 1/8 NPT plug as stated above. Nothing wrong with the screw and hose per se, but if it falls off for whatever reason, you'd be leaking boost.
Modified by inspyral at 3:09 AM 7/4/2005
builthatch
Jan 17, 2009 04:54 AM
cthan3o3
Dec 28, 2005 07:17 PM
Bartman201
Nov 2, 2005 10:42 AM
redlseg
Apr 27, 2005 03:34 PM
SRd240sx
Feb 5, 2005 01:49 AM
