greddy type s not making much noise
like the title says i just want to know why my greedy type s bov is so quiet. Also it is hooked up correctly. any suggestions?
Re: greddy type s not making much noise (Bailhatch)
mine is loud as hell, do you have the top nipple hooked up to to a vacuum source after the throttle body? also check the adjustment on it. hope this helps
Re: greddy type s not making much noise (7k rdlne)
its hooked up to the vaccum source on the fuel pressure regulator.and the adjustment is pretty loose
Re: greddy type s not making much noise (b18c1Monster)
It`s not very recomanded to use the vacum source on the fuel pressure regulator (Too Small) ! I recomend use the vacum from the pipe going to the brake booster it`s much biger and the vacum will be more powerfull .
Also don`t set it too loose because the spring will have no pressure and the sound will not be loud ! set it 50/50 that`s what`s my friend set at and it`s loud !
Good Luck
Good Luck
10 psi should be loud as hell. also, drawing vacuum source the fpr should be fine as long as there only feeds 1. hmmm....possiblity defective bov?
