quick question about deltagate wastegate
Old 09-26-2003, 09:54 AM
bumsta217's Avatar
Default quick question about deltagate wastegate
ok, im settin up my turno right now. I purchases a used deltagate. When i got it... theres two empty holes on top. I know one is for a vacuum line.... but waht do i do with the whole in the middle? any help would be greatly appreciated!
Old 09-26-2003, 10:29 AM
bumsta217's Avatar
Default Re: quick question about deltagate wastegate (bumsta217)
anyone??! help plz?
Old 09-26-2003, 10:30 AM
bumsta217's Avatar
ttt
Old 09-26-2003, 11:00 AM
ykracing's Avatar
if I remember correctly, there should be an allen bolt in the center hole...
this is the adjustment bolt...
there should only be two vaccuum ports available, one on the side of the unit, and one on top, but not in the center, kinda offset...
hope this helps... and keep in mind that I havent had a deltagate for a few years, so I could be wrong...
Old 09-26-2003, 11:54 AM
camp1320.com's Avatar
Default Re: quick question about deltagate wastegate (trboCIVICWRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trboCIVICWRX &raquo;</TD></TR><TR><TD CLASS="quote">if I remember correctly, there should be an allen bolt in the center hole...
hope this helps... and keep in mind that I havent had a deltagate for a few years, so I could be wrong...</TD></TR></TABLE>
ON the money
Old 09-26-2003, 12:38 PM
15psi of fun's Avatar
Default Re: quick question about deltagate wastegate (camp1320.com)
I have the deltagate and I took the bolt out of the top so it would clear my hood and im not using the vacuum line on the top. If you are using a MBC you don’t need the top line.
Just a little info to help
Old 09-26-2003, 01:23 PM
luti's Avatar
Default Re: quick question about deltagate wastegate (EFrollingout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFrollingout &raquo;</TD></TR><TR><TD CLASS="quote">I have the deltagate and I took the bolt out of the top so it would clear my hood and im not using the vacuum line on the top. If you are using a MBC you donÂ’t need the top line.
You took the bolt out? Doesn't that affect its settings at all?
B18EG6
02-07-2007 07:30 PM
krazyhmongboi
14
11-14-2006 12:33 AM
tdo
10-16-2005 10:33 AM
Dammit_Dan_954
02-02-2004 11:06 AM
Bert
02-26-2002 10:34 AM
Quick Reply: quick question about deltagate wastegate
