quick oil line question
Old Jun 3, 2003 | 01:34 PM
jspek29's Avatar
Default quick oil line question
i put on my oil line feed for my turbo 2day, but when i started the car oil is leaking from the fitting around the block, i have a bspt on the block and oil pressure switch teed off i have teflon tape on them, but they are still white so i dont think they are leaking, my question is are u suppose to put teflon tape on the fitting that goes to the oil line,? because that where it looks like it leaking, i took it out three times and taped it and made sure it was tight still leaking.PLEASE HELP , AFTER THAT IS FIXED I CAN SEE WHAT IT LIKE BOOSTED
Old Jun 3, 2003 | 02:15 PM
DeepSi's Avatar
Default Re: quick oil line question (jspek29)
are you the one that assembles the ss lines? Are the fittings on right? On compression fittings you are not suppose to use telfon tape.
carlos8
Mar 20, 2012 06:20 AM
Dre90
Apr 20, 2010 04:11 PM
MikeMAN
Jul 2, 2002 09:25 PM
GruvyTune
Feb 5, 2002 01:46 PM
AutoboTxEK
Nov 29, 2001 12:16 PM
