quick inline resistor install ?
Old Dec 8, 2003 | 11:20 AM
fastcivicboy's Avatar
Default quick inline resistor install ?
Hey everyone i just bought some 10 watt 10 ohm inline resitors and im installing them on my obd1 civic for my 450's. I just run them inline on the yellow wire with the black stripe coming off of the injector right and leave the other wire alone. Is this correct? I think so but just want to make sure! Also do I need to grind down the little bump in the inside of my 450 to make it fit in my obd1 clips?
Old Dec 8, 2003 | 11:32 AM
anyone
Old Dec 8, 2003 | 12:52 PM
up
Old Dec 8, 2003 | 02:40 PM
IntegracinGSR's Avatar
i am wondering the same thing because i just bought 450's also.. do any modification need to be done to make them fit?
Old Mar 29, 2005 | 03:35 PM
Hayaimoto's Avatar
Default Re: (IntegracinGSR)
yes grind down the bump for the dsm injector, then they should fit!
Old Mar 29, 2005 | 05:48 PM
EJ1 wilcox's Avatar
Default Re: (JDMerzxCEO)
Yup... you got it right...
Solder the resistors inline to each injector in the yellow wire with a black stripe... and cut the little tab on the inside of the clip off to make them fit...
Old Mar 29, 2005 | 10:21 PM
drumking15's Avatar
this works for any peak and hold style injector correct? like precisions
MBlake55
Aug 2, 2007 05:10 PM
Eluzion
Sep 11, 2004 11:36 PM
APEXI Si
Feb 21, 2004 03:50 PM
Del_Slowest
Oct 21, 2003 08:20 PM
genop
Nov 20, 2002 08:21 AM
