quick help with hondata and injectors
Old Nov 4, 2002 | 07:43 AM
PM-Performance's Avatar
Default quick help with hondata and injectors
ok i have a hondata 4b , i was getting ready to order injectors. i think im gonna go with the RC550's, but do i need peak and hold or saturated? to wir with the hondata
Old Nov 4, 2002 | 07:54 AM
Default Re: quick help with hondata and injectors (itr206)
anybody?
Old Nov 4, 2002 | 07:58 AM
DeepSi's Avatar
I believe it does not matter which kinda injectors you use. if you peak/hold you need a resistor box.
Firedrake's Avatar
If you've got an ITR, then your car came with saturated injectors.......I don't know of any saturated injectors larger than 440 cc's as the design of the injector prevents any higher flow rates (don't ask me why though) so those RC's are peak and holds, which means you'll need to wire in a resistor box to run the peak and hold injectors properly....
Brian
Old Nov 4, 2002 | 08:01 AM
Boostfed's Avatar
New User
Peak and hold plus aa resistor box wired in, it's ery easy and instructions on Hondata web page helps. RC makes saturated up to 440ccs injectors then go to peak and hold as non custom injectors. Now RC has saturated injectors from 550cc up but you will pay alot i think approx $175 an injector. Easier to go peak and hold and resisitor box from a 90-91 Integra or 88-91 Civic Si or any of the older Hondas using peak and hold injectors, Prelude and Accords had a funky looking little one, cheap like $25 from a junkyard. HTH
Old Nov 4, 2002 | 08:03 AM
Default Re: quick help with hondata and injectors (Firedrake)
so there are no saturated injectors over 440?
Old Nov 4, 2002 | 08:07 AM
DIRep972's Avatar
Smarter than you
u can run either, but if u run peak and hold injectors u will need a resistor box. u can get from older 88-91 hondas I cant remember exactly which models.
Old Nov 4, 2002 | 08:10 AM
Firedrake's Avatar
Typically all injectors over 440cc are peak and hold.....Boostfed just said that RC will custom make saturated injectors over 550cc but they're $$$$.....I had always thought that something about the injector design of saturated injectors made getting flow rates over 440cc's not possible or cost-prohibitive.....any injector techies out there care to explain? (my injector design knowledge is lacking)....
Brian
Old Nov 4, 2002 | 08:14 AM
hmmm , im deff learning moer as i go with trying to get this kit working . no easy way out
. . . . whats everyone else heere running with their hondatas ?
Old Nov 4, 2002 | 08:16 AM
DC2R714's Avatar
Pete I would go with either the 550's or 720's. Remember SGT has that base map wit 720's that would get ya going till you had time to hit the dyno.
Old Nov 4, 2002 | 08:27 AM
Default Re: quick help with hondata and injectors (DC2R714)
yea thats why i was thinking that . ahh christ well hopefully the ones that Viren was gonna get me already have the clips and boxes and **** for them . ? IM running low on cash now .
Old Nov 4, 2002 | 08:34 AM
Sonny's Avatar
Injectors almost never come with a resistor pack and clips. If you need a set, see my sig.
If you're running larger than 440cc and you don't wanna pay out the a$$, peak and hold is the only way to go.
Sonny
Old Nov 4, 2002 | 08:40 AM
Default Re: quick help with hondata and injectors (Sonny)
hmmm , so honda used to have them stock? i prob have some laying around our shop then , im gonna double check .
integracivic94
Dec 30, 2003 06:49 AM
Hoodwinked
Aug 23, 2003 12:32 AM
GOLDBERG
May 6, 2003 05:00 PM
civcexcoupeblack
Dec 16, 2002 01:16 PM
SIK IN DA HED
Mar 12, 2002 02:39 AM
