Quick FMU+Missing link Question
Old Dec 29, 2009 | 12:39 AM
kpjo4's Avatar
Default Quick FMU+Missing link Question
Flame away if need be, I understand this method of fuel management is garbage against today's tuning technologies.
This is my first forced induction build it is an experiment (hence why i'm starting with a fmu).
I've collected myself a custom turbo setup and was wondering on a stock b18b1 will the oem fuel pump work or should I upgrade to a Walbro 255 lph if my plans are pushing 8psi of boost on a 12:1 fmu. =]
Old Dec 29, 2009 | 05:42 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: Quick FMU+Missing link Question
according to your location you live in texas. Im not going to advise you to use an FMU. You have enough tuners here in texas to do it right. If you use an FMU you risk the chance of running very lean or very rich. Usually lean.
take the time to read in the Engine Managment/tuning forum that will help you make the correct decisions
Old Dec 29, 2009 | 08:04 AM
dpetro1's Avatar
your logic of starting with an FMU as an entry level fuel management is faulty. FMU's are not a starting point, they are pretty much obsolete at this point. its like saying you are going to start with a tape deck before you move up to a CD player, pointless.
but to answer your question, FMU's create high fuel pressures, you will need an inline pump up supply the pressure or a 255HP in-tank may hold up at low boost.
EDIT: actually i dont even think the 255hp will do it. 12:1 fmu x 8psi = 96psi + 38psi base = 134psi. the 255hp can only flow like 8lph at that pressure.
Old Dec 29, 2009 | 09:09 AM
rick_rabies's Avatar
I'm not Rick!
sum guys here added the walboro intake pump and used fmu and ran at 8-10-12lbs of boost just fine. they are low budget/super old skool drag racing/smell like smoke and drink alot beer type a dudes. works fine if you use them right.
Old Dec 29, 2009 | 10:13 AM
dpetro1's Avatar
this may be possible with a lower ratio FMU ex: 4:1 or 8:1 but not at 12:1. 12psi x 12:1 fmu = 144psi + base of 38 = 182psi of fuel pressure. The walbro flows 0 lph at that pressure, hell i dont even think an inline pupm can keep up at that pressure
Old Dec 29, 2009 | 12:44 PM
boostedcivicsir's Avatar
Mr. Badwrench
the first 3 years on my car with a 255 (the hp one) and an fmu no issues, other than it being crap.
to answer your original question, no a stock fuel pump is not enough for the fmu. a walbro alone will work but an inline will help much more.
although i never ran my walbro at that high of a pressure, i did run it around 8psi.
Old Jan 4, 2010 | 02:05 PM
Unlimited Auto's Avatar
New User
You can physically run 12psi with an FMU and 255lph fuel pump (DONT DO IT THOUGH)... It will go lean and I have done it.. 7 years ago. The fuel pump does not stop flowing at that rate, basically because the fuel pump cannot push the pressure needed to return fuel to the tank it just stops the fuel at the fuel rail.
It is cheaper and safer to run crome.
You will find that your stock fuel pump cannot match the demand at about 4-5psi with a 12:1 FMU and it will start to go lean...
Old Jan 10, 2010 | 05:20 PM
frizzle's Avatar
i recomend an adjustable fmu and wideband o2. and why not a meth/water injection kit. a guy that i was talking to about this subject( inwhich ive been considering myself) says it needs to be ran on a ratio closer to 2:1 from an fmu
Old Jan 10, 2010 | 05:35 PM
jdm inc's Avatar
I would recommend on getting it tune on an ems so you will get full potential from the turbo setup and throw the fmu in the trash lol
Old Jan 10, 2010 | 06:05 PM
cjordan's Avatar
x2
you dont have to buy an expensive ems there are plenty of budget options out there that will save your motor and make you enjoy your setup that much more. I ran an FMU for 3 months before I developed a hole in a piston. Not saying the FMU was to blame but it sure didnt help
Old Jan 10, 2010 | 06:19 PM
fishieman's Avatar
If you are really on a budget instead running FMU, you should just get:
DSM 440cc's
And get a chipped ecu w/turbo basemap from John Vega - HT member "MTBER".
You'd probably run a tiny bit rich, but you'd spend less than $150 for both.
Old Jan 10, 2010 | 08:07 PM
frizzle's Avatar
DSM 440cc's
i thought about that myself. all i would need was a chip. but how safe is that really? and like in my area what if none will work with anything other then hondata so you could get it tuned to a fine point?
and about the fmu: so nobody thinks it can be tuned close to perfect? im just weighing options and learning myself. so i would like someone to explain what i am missing. and i know its primitive mechanics but isnt it what people were doing before they realized they could directly hack ecus? i guess i just see it as doing the job manually. i dunno thanks guys lol
Old Jan 10, 2010 | 08:41 PM
kpjo4's Avatar
thanx for all the advice everyone.
My motor at the momentis showing low compression of 120-125 psi in all 4 cylinders and then shoots up to 150 psi after a wet compression test (so it must be something within the block, most likely piston or rings). I was wondering if I should go oem pistons or something lower... possibly even higher (lol)
Old Jan 10, 2010 | 11:23 PM
fishieman's Avatar
Basemaps are far safer than running FMUs.
Old Jan 11, 2010 | 05:12 PM
frizzle's Avatar
And then I've heard otherwise.just makes it hard to know were to put my money. But I guess spend money on a wideband and in my case get a base map chip for my setup and see how it mixes out. Wouldn be too bad untill I got some software on it myself maybe.
Old Jan 11, 2010 | 05:24 PM
jdm inc's Avatar
If u are on a budget you can run something like crome and find a tuner to tune it to get the full potential from your setup cuz im sure u will want more power in the long run.
Old Jan 12, 2010 | 01:18 AM
russlan44's Avatar
just turbo'd my d16 del sol with 200k running 12:1 FMU and missing link @ 5psi 3days so far so good, but today car started to over heat after going through couple of gears, and also about running rich or lean, would i be better of with 9:1 FMU disk? and yes i know FMU's arent the best thing thats out there saving $ for hondata and tune
Old Jan 12, 2010 | 11:38 AM
Turbo-LS's Avatar
one word comes to mid when i see these silly questions
KAAABOOOOOOOMMMMMM
Or would that be catagorized as sound?
Old Jan 12, 2010 | 11:43 AM
jdm inc's Avatar
you should get a wideband to make sure.
Old Jan 12, 2010 | 06:42 PM
fmfkid250's Avatar
2010.
b18bteg14
Dec 10, 2006 02:46 PM
deca
May 3, 2005 12:15 PM
steelies
Nov 7, 2004 10:52 AM
f1 vtec
Aug 28, 2004 07:50 PM
mz3bo
Jan 19, 2003 12:47 AM
