questions about oil lines for prelude.
Old 05-21-2008, 04:25 PM
92prelude23's Avatar
Default questions about oil lines for prelude.
does it matter which port you use to get the oil to return and drain on the turbo?
Old 05-21-2008, 04:35 PM
I dont think i made that very clear... Does it matter which side of the turbo is the Oil Feed & Return
Old 05-21-2008, 05:15 PM
Str8 outta Cliff's Avatar
Default Re: (92prelude23)
Yes
Old 05-21-2008, 05:36 PM
boostedh22lude1's Avatar
Default Re: (Str8 outta Cliff)
feed line will have threads inverted into the turbo
Old 05-21-2008, 06:05 PM
Im sorry i dont really understand can you make it more clear? im new at all this and im trying to learn. thank you.
Old 05-21-2008, 06:25 PM
the oil feed line (oil pressure line) goes on the side with threads (fitting threads into turbo) make sure you run the oil lines vertical, with the feed line on top, the drain will have a threads also but will have 2 bolt holes to bolt a drain tube hopefully that helps
CivicDude2k4
09-05-2006 08:24 PM
SiR99
06-11-2006 09:09 PM
MotorMouth
03-20-2006 07:12 PM
radioren
02-07-2005 08:15 PM
Quick Reply: questions about oil lines for prelude.
