question on wastegate setup
Old Jun 3, 2009 | 06:27 PM
twilson's Avatar
Default question on wastegate setup
FYI - this is a no name wastegate.
Call me a noob or whatever you like, but my question is:
On my current setup, I only have one vacuum line coming off the bottom air fitting on the wastegate and it goes to the bov/intake mani.
The hole on the compressor side of the turbo is plugged (doesn't a vacuum line usually go here?). Basically, I don't have an air fitting on top of mywastegate going to the turbo.
Is this weird? If it's not making any sense, maybe I can get some pics for visual
Thanks.
Old Jun 3, 2009 | 06:31 PM
marcj's Avatar
Default Re: question on wastegate setup
you don't use the top fitting on the wastegate unless you're running an electronic boost controller. run the bottom fitting to a better source of vacuum. I use the fitting on the turbo compressor for quick response. you will generally use a few psi in the intercooler so a 11psi spring might open at 9psi, like mine does.
Old Jun 3, 2009 | 06:41 PM
twilson's Avatar
Great. Thanks for the quick response.
Old Jun 4, 2009 | 11:02 AM
twilson's Avatar
So - It's ok to leave the top port empty. Should I plug the hole with something?
Only use the top port on the WG if I have an ELECTRONIC boost controller and don't use it for a manual boost controller either, right?
It's not going to create a leak if I don't use it?
I guess I'm dumber to this stuff than I thought.
Thanks!
Old Jun 5, 2009 | 05:47 AM
twilson's Avatar
Just wanting to make sure I have it setup correctly ...
Old Jun 5, 2009 | 07:05 AM
champLSinteg's Avatar
Yes, leave the top port unplugged if you are not using a boost controller, electric or manual. The bottom port is sealed off from the top so there is no leak to worry about.
Old Jun 5, 2009 | 08:23 AM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
Old Jun 5, 2009 | 08:39 AM
twilson's Avatar
OK - I do plan to install a MBC this weekend.
There is still no need to use the top port. I can just run it from the wastegate vaccum (lower air port) to the boost controller then tee into the intake manifold vacuum/BOV line.
Right?
monster_c
Apr 23, 2012 10:53 AM
desiromeo812
Nov 27, 2008 11:34 PM
ham
Nov 19, 2005 02:57 PM
sykotic
Dec 4, 2004 09:49 AM
StockBlockRob
Jul 30, 2004 08:34 AM
