question on oil pan
Old Jan 26, 2002 | 02:59 PM
RangerGuy's Avatar
Default question on oil pan
my buddy is putting a greddy turbo kit in his 2000 civic ex. there are two choices for the oil line. bolt it in after drilling a 15mm hole or welding it. which is better? i know honda pans are thin, so would welding it distort and create a weak spot? by that logic, would bolting it in do the same? figured you guys would know. ask a honda question, ask a honda guy
thanks!
chris
Old Jan 26, 2002 | 04:18 PM
SEFIxCivic's Avatar
Default Re: question on oil pan (RangerGuy)
welding it would be my first choice, bolting it on with a modified AN bulkhead + hondabond would be my second. On my oil pans I've had them welded and it never gave me any problems.
Old Jan 26, 2002 | 05:16 PM
RangerGuy's Avatar
Default Re: question on oil pan (SEFI8LOxCivic)
thank you! i assume that the oil pan is not too hard to remove? just messy?
lata
chris
Old Jan 26, 2002 | 05:17 PM
Arturbo's Avatar
Better than steak
25 Year Member
No even messy. Just drain the oil first.
Old Jan 26, 2002 | 05:31 PM
RangerGuy's Avatar
Default Re: question on oil pan (Arturbo)
hehe that would help abit
lata
chris
Old Jan 26, 2002 | 05:33 PM
cyan1de's Avatar
do you have to replace the oil pan gasket after you remove it?
Old Jan 26, 2002 | 05:46 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: question on oil pan (cyan1de)
Im very **** about stuff like that, but anytime I break a seal from anything I replace it.
art
Old Jan 26, 2002 | 05:51 PM
SEFIxCivic's Avatar
It depends on the condition of the gasket. if its dried up then time to replace it. otherwise it should be okay.
Old Jan 26, 2002 | 05:52 PM
fastestdriver's Avatar
If you drain the oil it takes away the challenge!!! Ya dude replace that pan gasket while you are there. Don't smear it with silicone either. Just make sure the pan and block surfaces are totally clean of oil (brake clean works great) and don't overtighten pan bolts.
Old Jan 27, 2002 | 12:30 AM
project dc2's Avatar
question ... what kinda welding do you guys use on your oilpans ? MIG or TIG ? also ART with the brass fitting that you use from home depot, will that work with a mIG welder on the honda oilpan ? will it not melt etcc? thanks
Old Jan 27, 2002 | 01:49 AM
SEFIxCivic's Avatar
Default Re: question on oil pan (project dc2)
mig will work. but remember we arent talking about welding those brass fittings to the oil pan. that is impossible. we are talking about welding steel -10 AN bungs.
Old Jan 27, 2002 | 06:13 AM
maxim's Avatar
I was told the MIG will not work with the 2000 EX oil pan, because it is aluminum. so in my case I had to find someone with a TIG.
Old Jan 27, 2002 | 06:54 AM
VaporTrail's Avatar
New User
art
I'm just going to let that one go...
fandango
Jan 20, 2005 06:20 PM
TheYellowDart
Dec 17, 2004 07:51 PM
JDM-EJ1
Oct 21, 2004 03:57 AM
shming123
Apr 16, 2003 11:12 AM
GruvyTune
Nov 12, 2001 04:07 PM
