Question on FMU's
Old Feb 2, 2005 | 07:12 PM
lalspeed's Avatar
Default Question on FMU's
I noe this may have been discussed hundreds of times
but i need some help
how reliable is a fmu setup?
i have my setup almost complete and i noe uberdata is free but i cant afford the tuning just yet and wanted to know if i can run the fmu setup for a few months
thanks in advance
Old Feb 2, 2005 | 07:14 PM
93turbo16's Avatar
I hate the FMU setup personally, but it does work sometimes. WE need more info on your setup. I would just get uberdata and be done with it.. much more safe than a FMU setup.
Old Feb 2, 2005 | 07:29 PM
sharkcohen's Avatar
Default Re: (93turbo16)
I don't personally like the lack of flexibility of FMUs, but an adjustable unit can allow you to get by.
Old Feb 2, 2005 | 07:31 PM
lalspeed's Avatar
im using a redrilled hf mani on my ls with a t3
really basic jus starting out
with a high school budget
Old Feb 2, 2005 | 07:36 PM
Muckman's Avatar
Moderator in Chief
Default Re: Question on FMU's (lalspeed)
Its doable for low boost as long as its "tuned" with a wideband as with any fuel adjustment.
Old Feb 2, 2005 | 07:39 PM
SOHC_MShue's Avatar
Default Re: Question on FMU's (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">Its doable for low boost as long as its "tuned" with a wideband as with any fuel adjustment.</TD></TR></TABLE>
how can you "tune" a fmu?
I wouldn't run more than 7psi with the fmu just to be safe.
Old Feb 2, 2005 | 07:52 PM
Muckman's Avatar
Moderator in Chief
Default Re: Question on FMU's (SOHC_MShue)
obviously was refering to the adjustable ones... and if its not, they have different size disc's that change the fuel pressure increase per psi of boost - if you can call that tuning - which is also why I used quotations
Old Feb 2, 2005 | 07:58 PM
sharkcohen's Avatar
FMUs with adjustable rise rates, such as ones made by Car Tech, paired with a fuel controller like an Apexi AFC, can actually make for a decent setup for low boost. But it needs to be carefully set up with a wideband, like Muck said.
Old Feb 2, 2005 | 08:02 PM
dornon13's Avatar
Default Re: Question on FMU's (sharkcohen)
uberdata is too cheap to go the FMU route just think of the money you are saving on a blown motor
Old Feb 2, 2005 | 08:44 PM
The-LS's Avatar
FMUs are fine, for basic setups running mild boosts I don't see why a FMU won't work. People ran them for years before Hondata or UD was even available and they worked great. Its obvious they aren't the best way to add fuel for boost, but you can't say they don't work.
Old Feb 2, 2005 | 08:45 PM
dornon13's Avatar
Default Re: Question on FMU's (Black-LS)
i agree they work..my buddy even runs one but uberdata is no more expensive than an fmu.
Old Feb 2, 2005 | 08:54 PM
lalspeed's Avatar
Default Re: Question on FMU's (dornon13)
thanks for the insight everyone
btw i said i dont have money for tuning jus yet
so the fmu will only be temporary
Old Feb 2, 2005 | 08:55 PM
lalspeed's Avatar
also by tuning with the wideband
i just have to find the right disk that gives a nice air fuel ratio?
Old Feb 2, 2005 | 08:58 PM
turbopimp's Avatar
don't forget the high pressure fuel pump you'll need with the fmu...
Old Feb 2, 2005 | 08:59 PM
The-LS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dornon13 &raquo;</TD></TR><TR><TD CLASS="quote">i agree they work..my buddy even runs one but uberdata is no more expensive than an fmu.</TD></TR></TABLE>
agreed, I'm running UD myself... but UD is not for EVERYONE, you really have to understand what your are doing to actually use UD. A FMU is pretty much bolt on.
Old Feb 2, 2005 | 09:08 PM
BoostedJeff's Avatar
20psi, sc61, vafc &lt;----- what i use.
You just gotta know what ur doin
Old Feb 2, 2005 | 09:47 PM
Joseph Davis's Avatar
Default Re: Question on FMU's (BoostedJeff)
haha
Old Feb 2, 2005 | 09:56 PM
s2kdre's Avatar
Default Re: Question on FMU's (J. Davis)
fmu is safe up to 10psi with no problems, you have to try it for yourself. They make my car so rich in boost i love it.
Old Feb 3, 2005 | 05:48 AM
dornon13's Avatar
Default Re: Question on FMU's (jdmhonda)
except you are losing so much power, it is doing nothing for your timing which could be dangerous, and your fuel rail pressure is outrageous
andyvaj
Mar 20, 2007 05:45 PM
tonezilla
Jan 13, 2004 09:09 PM
stinker504
Sep 15, 2003 05:38 AM
X2BOARD
Aug 11, 2003 08:18 PM
