Question: B20/VEC Turbo
Old Aug 31, 2005 | 01:52 PM
DjBurns's Avatar
Default Question: B20/VTEC Turbo
They i am looking a getting a B20 CRV block for a good price. anyways i have a 92 GSR with a B16 Turbo right now. but i want the TQ#s. so how well does a B20/VTEC work when boosted? i would have the block sleeved, and the pistons and roads done. then i can make the rest work with parts from the B16. so i should have everything i need. someone was telling me that the b20 crank is not as strong as the b16s. anyways i am just trying to get some info on this setup. i would like it to see from 14psi-18spi. right now i am running 11psi on my b16 with full stock internals as a daily driver. so any info i welcome.
thanks
Danny.
Modified by DjBurns at 7:14 PM 8/31/2005
Old Sep 2, 2005 | 12:58 PM
DjBurns's Avatar
does anyone have any info on this?
Old Sep 2, 2005 | 12:59 PM
2k.civic.si's Avatar
Default Re: (DjBurns)
b20 sleeves tend to crack....u may get lucky though....
Old Sep 2, 2005 | 05:12 PM
Silverhatch's Avatar
Default Re: (2k.civic.si)
yes he is right the b20 blocks arent that good for a turbo application unless sleeved . My buddy crack his stock sleeves on 260whp.... 8psi I think it was
Old Sep 4, 2005 | 10:15 AM
DjBurns's Avatar
so if it is sleeved then i should more then ok for that block to see around 16psi. thats with rods and pistons and all that good stuff.
the crank would be more then ok?
Old Sep 5, 2005 | 01:58 PM
DjBurns's Avatar
anyone?
Old Sep 5, 2005 | 02:02 PM
B20TDC2's Avatar
if you sleeve the block it will be ok . and i wouldnt worry about the crank . i rum 18psi daily on my built set-up
Old Sep 5, 2005 | 02:07 PM
BoOsTiN Dc2's Avatar
Default Re: (B20TDC2)
if you sleeve it then its pretty much the same as a LS motor. Sleeve it and put some forged piston and roads in there.
Old Sep 6, 2005 | 07:26 PM
DjBurns's Avatar
so the length of the stroke will not be an issue?
Old Sep 7, 2005 | 12:17 AM
B20TDC2's Avatar
no it shouldn't if your worried about high to rev it with my old set-up i took it to 8300 with the one currently being built i'm going to take it to 9500
Old Sep 8, 2005 | 11:07 AM
icivicracer's Avatar
i think the stroke is the same as an ls just the bore is bigger.. i have a jdm b20 with jrsc at 8 lb no problem yet.. stock sleaves..... just tune the hell out of it
SinsEvil666
Jan 28, 2008 08:57 AM
l3owen
Feb 7, 2004 11:13 AM
l3owen
Feb 7, 2004 08:17 AM
D3LSLO
Aug 24, 2003 09:05 AM
kmf0211
Feb 20, 2003 09:37 PM
