Question about Water Methanol Injection
Old Jan 31, 2009 | 05:14 AM
twistedframe512's Avatar
Default Question about Water Methanol Injection
I checked the boost FAQ and tried to use the search feature but couldn't find any good info on my question. I'm trying to hit about 300hp in my F22B1 and was just wondering if water injection would be beneficial or needed for this relatively moderate number. BTW its not going to be super high compression just 8.8:1. Thanks in advance for any info you guys can provide.
Old Jan 31, 2009 | 08:47 AM
malink's Avatar
Default Re: Question about Water Methanol Injection
Way #1 - if you are running near the edge of safety on Pump Gas and higher boost level, water/meth injector will increase the octane of the fuel/air mixture entering the combustion chamber as well and lower the charge temps which helps stave off detonation from whatever the source. If you tune the car on pump without any injection and then add the injection later, you will barely lose any power at all if any and run much safer for very inexpensively. Also, if you run out of Meth or the system ever fails...you are tuned here and you arent relying on the meth so chances are, nothing bad will happen
Way #2 - if you are trying to surpass the detonation threshold using pump gas (not using race gas) you can tune using Water/Meth injection to increased power levels by tuning leaner and meaner (more timing) as the increase in octane and lower charge temps allow you to raise the detonation threshold. However, if you run out of Meth or the system ever fails...no doubt that bad things will surely follow, immediately.
Old Jan 31, 2009 | 11:15 AM
bobby taylor's Avatar
I 2nd THAT!!!
Old Jan 31, 2009 | 12:56 PM
srmofo's Avatar
well said...however 300 isnt that much power to be made. I dont see any reason why you would need it. save your money for good mangement and a proper tune and you should be just fine without water injection
Old Jan 31, 2009 | 02:13 PM
malink's Avatar
its also depends on what kind of mixture you want. I run 50/50 and so far i never had a problem with my car
Old Jan 31, 2009 | 04:20 PM
ACTION JACTION's Avatar
You can make much more than 300whp safely on pump gas. I would say the safe limit on pump gas is around 450-500 depending on what octane is available. If you tune on pump gas and add water/meth, then power should go up slightly and your safety margin increases as well, if anything were to happen.
Old Jan 31, 2009 | 04:30 PM
Turbo92cx's Avatar
Spend the money on TUNING!!!!! Water/Meth is not needed with the HP you are looking for you can safely surpass 300hp on pump gas with the right Fuel management and tuning!!!
NIKADEM0
Mar 3, 2014 06:12 AM
mdixonjam
Apr 25, 2005 04:25 AM
TurboMiata
Oct 27, 2004 11:04 AM
slowcarguy
Jan 13, 2003 07:25 AM
AlphaKennyWun
Jul 3, 2002 09:58 PM
