manifold issue...help!!
Old Mar 20, 2011 | 07:44 AM
96electronH's Avatar
Default manifold issue...help!!
i recently bought a bmc log manifold that has the old style 4 bolt 44mm wastegate flange. for one the only wastegates i have seen that are 44mm are vband. second of all i think 44mm wastegate is overkill for a setup that im planning on only making 275whp max. what i was thinking is getting a 38mm flange like you would for making a dumptube and cut the 44mm flange off the manifold and weld the 38mm in its place. i think it would work but would like some input or advice from you guys. thanks in advance
Old Mar 20, 2011 | 08:23 AM
Gunmetal_B20_Hatch's Avatar
Default Re: manifold issue...help!!
I dont understand how it WOULDNT work...
Old Mar 20, 2011 | 08:26 AM
i thought it would to i just wanted to get another opinion before u hack the old flange off. i just hope that the 38mm flange leaves enough room for the existing pipe to weld onto it that was my worry
Old Mar 20, 2011 | 08:29 AM
this is the manifold
Old Mar 20, 2011 | 08:32 AM
SovXietday's Avatar
You can, but the 44mm is a little big of a pipe for the 38mm.
Why not just dig around and find an old 44mm or rather just cut the flange off and have a 44mm vband welded on? It's never a bad thing to go bigger with the wastegate...
Old Mar 20, 2011 | 08:39 AM
i know the 44mm is big but i dont think would matter for my setup as long as the flange could weld up.
i have tried searching for 44mm and most are vband which isnt bad i could weld on a vband but the wastegates are so much more expensive than a 38mm and i was trying to keep it a budget setup.
Old Mar 20, 2011 | 10:39 AM
EsotericImage's Avatar
Retired Moderator
ditch the manifold and buy one suited for your needs.
This shouldve been researched first before" buying then researching".
Old Mar 20, 2011 | 12:34 PM
Id rather make the one I have work
Old Mar 20, 2011 | 02:28 PM
SovXietday's Avatar
Your best bet is to either ditch the manifold and get one that fits your needs or find an old 44mm with the 4 bolt flange.
Going up in size is easy, you just drill out a bigger hole and go. Going down is a problem, because you have to fill the hole, and you really shouldn't just weld a 38mm 2 bolt because it will be a pretty nasty choke.
Old Mar 20, 2011 | 02:40 PM
I have been looking for a 44mm with a 4 bolt all I can find is ebay junk. Ill keep looking or I guess ill have to get a new manifold
Old Mar 20, 2011 | 03:28 PM
94VTEC2TONE's Avatar
call inline pro, get somethings like this and be done
Old Mar 20, 2011 | 04:30 PM
Wow that looks good ill have to see what they could do for me
Old Mar 20, 2011 | 06:14 PM
wantboost's Avatar
Who is Mr Robot?
that wont fit what he has... and inline pro does not make a 44-anything adapter.
I swear to christ members are getting dumber
Old Mar 21, 2011 | 04:44 AM
I knew that obviously was not the right adapter for me I think he was trying to let me know thy may be able to fab something up. Looks like ill be buying a new manifold.
KdF
Sep 23, 2010 07:14 PM
TwoKSiR
Jul 25, 2009 08:38 AM
Patron
Feb 13, 2004 08:35 AM
evoeone
Mar 6, 2003 05:40 PM
