Question about intercooler cooling efficiency, thickness vs. height/width.
Old Jul 1, 2005 | 10:41 PM
O16581724 5 2 5's Avatar
Default Question about intercooler cooling efficiency, thickness vs. height/width.
I didn't know what to Google search for, so i'm posting.
I've heard that overall thickness of an intercooler is what really gives it the cooling properties. The reason i'm asking is because i've found a 600MM (width) X 300MM (height) X 76MM (depth) for the same price as: 460mm X 160mm X 90mm
The second one fits like this:
The first one will have about 140mm of the intercooler tucked behind the bumper unless i cut it, but from side to side, will have more core exposed. There is a full piping kit for the first one, the second one i will have to spend a little more and do some fabricating of charge pipes to make it work. If the cooling properties won't be different, i don't see wasting my time, i'd assume since there's a vast difference in overall core size, it would.
Old Jul 3, 2005 | 08:52 AM
stmizner's Avatar
depth of the core has alot less to do with cooling than frontal surface area. the air heats up as it goes through the core and is less effective at cooling the further through it is.
maximum boost should be required reading!
Old Jul 3, 2005 | 11:10 AM
Default Re: (stmizner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stmizner &raquo;</TD></TR><TR><TD CLASS="quote">the air heats up as it goes through the core and is less effective at cooling the further through it is.</TD></TR></TABLE>
...What?
Old Jul 3, 2005 | 11:25 AM
Bailhatch's Avatar
Default Re: (x O 16581 72452 5 x)
he's saying that if you have a 4" thick core, the fisrt 2" that the ambient air hits are doing more work than the last two since the temp of the ambient air is higher the further it goes through the core. After a point you are getting diminished gains in cooling by adding thickness. All you gain is flow, but a better way to get more flow is to add rows not thickness.
Old Jul 3, 2005 | 02:23 PM
stmizner's Avatar
Default Re: (Bailhatch)
Old Jul 4, 2005 | 12:58 AM
I see, i was thinking something else.
Thanks for the help.
TravisBiggie
Jun 21, 2012 09:50 PM
See Are X
Sep 9, 2004 03:02 PM
RICE POLICE SIP
Feb 28, 2004 05:25 PM
JM Performance
Dec 30, 2003 07:40 PM
igo4bmx
Jul 13, 2003 09:50 PM
