Quaife LSD on 400whp?
Old Sep 12, 2003 | 06:27 AM
austrian type-R's Avatar
Default Quaife LSD on 400whp?
Anyone has an Quife LSD on his high hp beast? Will it hold? How to compare to stock ITR Thorsen LSD, which seems to hold the power.
Old Sep 12, 2003 | 06:49 AM
b18bturbo's Avatar
Default Re: Quaife LSD on 400whp? (austrian type-R)
QUAIFE is the best hands down....
Too many drag racers use it with over 600HP+
Christian you wont be diasspointed with one in your car..
Old Sep 12, 2003 | 06:50 AM
b18bturbo's Avatar
Default Re: Quaife LSD on 400whp? (b18bturbo)
Also the lifetiem guanrantee cant be beat.....
Old Sep 12, 2003 | 07:11 AM
boosted hybrid's Avatar
It will easily hold, and there is def. an improvment over the factory torsen unit. A friend made the switch from the OEM itr diff to a quaife, he swears it pulls more consistent into the corners.
Old Sep 12, 2003 | 07:22 AM
GreddySi99's Avatar
Default Re: Quaife LSD on 400whp? (boosted hybrid)
its the only one I would trust!! lifetime warranty no questions asked
Old Sep 12, 2003 | 07:37 AM
liam821's Avatar
25 Year Member
Default Re: Quaife LSD on 400whp? (intercooledJRSC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by intercooledJRSC &raquo;</TD></TR><TR><TD CLASS="quote">its the only one I would trust!! lifetime warranty no questions asked</TD></TR></TABLE>
More importantly, a lifetime warranty under race conditions!! Which is just awesome!
liam
Old Sep 12, 2003 | 08:01 AM
integranator's Avatar
Default Re: Quaife LSD on 400whp? (liam821)
95c1v1cs1 has it on his 406hp 330ft/lb monster. Bitch holds up to all of his launchs and takes it!!
Old Sep 12, 2003 | 08:14 AM
quikB18B's Avatar
Default Re: Quaife LSD on 400whp? (integranator)
The oem Itr would be sufficient for a mild turbo setup if your on a budget, but **** for 400whp you definietely want to go with a quaiffe. It really depends on your budget/goals. But if you making 400whp and go with the ITR, if it goes and you buy another one you could havepretty much bought the quaiffe for that price with warranty.
Old Sep 12, 2003 | 08:46 AM
MikeMAN's Avatar
It WILL hold the power, talk to tony1, I don't believe they have ever had one break and you can't beat the lifetime warranty.
mike
Old Sep 12, 2003 | 08:48 AM
Erik B's Avatar
Boosted99si uses it on his 400whp Civic
Old Sep 12, 2003 | 08:51 AM
FredoSP's Avatar
Default Re: (Erik B)
soon I will have one too
Old Sep 12, 2003 | 09:21 AM
Rhman19's Avatar
Default Re: (FredoSP)
Quaife . I haven't heard of one breaking except someone earlier said Tran has, but I don't know.
95lstegman
Feb 3, 2005 11:18 AM
mr devious illusions
Mar 16, 2004 11:27 AM
fastlude69
Feb 4, 2004 10:20 AM
CRVEF8
38
Jan 11, 2004 12:10 AM
Wazup
May 18, 2003 10:07 AM
