h22 or h23 for boosting
Old Sep 5, 2003 | 12:32 PM
buck02's Avatar
Default h22 or h23 for boosting
i have both a h22 closed and a h23 closed deck which would be better for boosting of course sleeved and fully built i have both but want to build a extra block
Old Sep 5, 2003 | 06:13 PM
buck02's Avatar
Default Re: h22 or h23 for boosting (h22civic2)
ttt
Old Sep 5, 2003 | 09:18 PM
f22a's Avatar
if you already have both motors, it is all a matter of what you decide. this will always be debatable and subjective to the person giving their opinion. if i already had an h22 i would just turbo that...
Old Sep 5, 2003 | 09:23 PM
bambooluv's Avatar
Default Re: h22 or h23 for boosting (f22a)
H22 for sure man. Theres no need to go larger. If anything try to get a de stroker crank in the h22 to about 2.0 and rev the crap out the motor -pdang
Old Sep 5, 2003 | 10:21 PM
buck02's Avatar
Default Re: h22 or h23 for boosting (bambooluv)
were can i get a destroker and out of what
buck02's Avatar
what is a good sleeve liner to put in the close deck blocks or ley m say sleev all together in a close deck block
Old Sep 8, 2003 | 03:02 PM
buck02's Avatar
anyone else help me and what are the best sleeve s or liners to use please help
Old Sep 10, 2003 | 06:18 PM
buck02's Avatar
best h22a1 close deck sleeves to use or liners
Old Sep 10, 2003 | 07:34 PM
KStuned's Avatar
Dartons pro kit is excellent. However Darton also has the sleeve replacements, which are quite a bit cheaper. When ordering, just make sure you get a "flanged" sleeve, so there is no possibility of sinking a sleeve. The Pro kit from Darton is a full flanged sleeve, to convert an open deck H22 (97+)into closed deck, but it still works on the already closed deck H22's (93-96) as well!
Old Sep 10, 2003 | 07:38 PM
buck02's Avatar
Default Re: h22 or h23 for boosting (Hondaddict)
what kind of price tag and who can i get account to get some block done
Old Sep 10, 2003 | 07:40 PM
PrecisionH23a's Avatar
I am a little tied up at the moment, but i can answer the majority of questions you have about the h23 or h22a.
Darton sleeves is what you need to go with, Golden Eagle is also a reputable company. You must run these if you run a forged pistons. The only exception are the WISECO rings that are made for the FRM cylinder walls. But it's better to do it right the first time then to do it a second time.
What kind of power are you hoping to put down and what are your goals for the car?
Old Sep 10, 2003 | 07:43 PM
buck02's Avatar
Default Re: h22 or h23 for boosting (GudeH23a)
i have a ari sleeves in one of my blocks now tring to get 600hp out if it i have anothe h22 close deck tring to sleeve it too and i have good deals with golden eagle and dont know much about darton trhough wanting to build a extra block or a main block and oull mine us it for back up
Old Sep 10, 2003 | 07:45 PM
KStuned's Avatar
What?????
IF you're asking the price, and where you can get it done it is roughly:
Flanged sleeve replacements appx. $300
Darton Pro Kit appx. $550
I forget how much I paid for install of my sleeves
You can call Darton, they can recommend a machine shop near you to do QUALITY work, or you can send it directly to Darton. OR.... Golden Eagle also has great sleeve kits,... but the turnaround time can sometimes be quite a while, but that is to be expected with machine work.
I had my engine done at: Edwards Supreme Engines in Spokane, contact Civicsitek, or Emerika on this forum. 93Lsivic also sells and installs Darton sleeves.
Isn't the motor that is in your car already built and sleeved?
Old Sep 10, 2003 | 07:47 PM
bambooluv's Avatar
you can run with GE or aebs sleeves both good choices. for the destroker crank call either ben at aebs or crower.-pdang
Old Sep 10, 2003 | 07:52 PM
KStuned's Avatar
I expect AEBS might have a stroker crank, but CROWER? H22 gets no love. I am VERY interested to see if someone has a destroker kit available, then again, there is no replacement for displacement !!!
Old Sep 10, 2003 | 07:57 PM
buck02's Avatar
yes the one in my car is completely built and i want to sleave another but its close deck and yes i would to find out how to destroke my block
Old Sep 10, 2003 | 08:06 PM
The H series is not the best motor in the world to go about high revving. Would you care to shed some light on destroking the H22 to a 2.0 with me? Honestly, I would keep the 2.2 for the increased displacement and keep the revving in the 7-7500 range. You are not going to find a turbo camshaft for the h22 that will produce a large amount of power past the 8k range. And keep in mind, all H series camshafts are Re-Grinds. Besides JUN of course, which are geared towards all-motor, and Crower also makes some nice ones. Personally, I think destroking the H22 is not a good idea. My h23a is up to around a 2.4L now and it will be on the dyno next friday shooting for mid to high 400's. If i get some ***** I might just take it up to 500whp.
I have not seen a single high powered H series motor with a destroker kit in it. But then again, I am sure there are some people out there that have it.
Let's talk some tech about the issue so we can all learn a little more then we originally knew.
Old Sep 10, 2003 | 08:16 PM
buck02's Avatar
well from what i hear the jdm type s cam is the best way to go with turbo hands down
thats what lance ho lung was running but now on the destroker yes would love to do but prob will stick with the normal h22 i have i would love to get my hands on a open deck for the larger journals but this is all i have is a extra h22 closed
well i have a h22a4 open but it threw a rod and the messed up the girdle and the bottom of the block a little so i really can tuse it i wish though i may post some pics of it ad let yall tell me what yall think
thanks guys for all the help
Old Sep 11, 2003 | 09:29 AM
buck02's Avatar
ttt
Old Sep 12, 2003 | 09:26 AM
buck02's Avatar
_______
wafflecopter
Apr 22, 2015 12:30 PM
h23guy
Jul 11, 2013 03:38 AM
jllong95
Jun 3, 2008 08:36 AM
2.2SICKLUDE
Aug 29, 2003 03:46 PM
