qiuck help me safc high low thrittle
#51
![Default](https://honda-tech.com/forums/images/icons/icon1.gif)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tchleung »</TD></TR><TR><TD CLASS="quote">The higher the negative number, the leaner you are. What motor is this on? and again, waht are the NE-Point's set to?</TD></TR></TABLE>
d16y8 motor. and that is what ive been askin. what do i set the ne points to. i didnt set them yet
#52
hey wait a second. D16Y8? Isn't that the SOHC VTEC? And you're running a SAFC and not a VAFC? Am i correct?
Since it's the SAFC, you don't have the feature of Ne-P:Hvt and Ne-P:Lvt, so for the Ne-Point, I would jsut set it to cover your whole RPM band like:
1000
2000
3000
4000
5000
6000
7000
8000
Something simple to start you off
1000
2000
3000
4000
5000
6000
7000
8000
#55
Hrm.. -39 shouldn't make you run so rich that'd it'd foul the plugs that bad and cause misfire... -39 is a pretty good area most people use... what's your fuel pressure at?
#56
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tchleung »</TD></TR><TR><TD CLASS="quote">Hrm.. -39 shouldn't make you run so rich that'd it'd foul the plugs that bad and cause misfire... -39 is a pretty good area most people use... what's your fuel pressure at?</TD></TR></TABLE>
so i should lean out the low throttle right? to like -45 or something?
#60
If you are still going rich lean it out to -45. You car might be different than the others.
It also occurs to me that your resistors may be wrong. I have heard of sputtering issues using radio shack resistors that was fixed by using an Acura resistor box.
#61
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy »</TD></TR><TR><TD CLASS="quote">I have heard of sputtering issues using radio shack resistors that was fixed by using an Acura resistor box.</TD></TR></TABLE>
Good point, I just read something talking exactly about that a few days ago.
abmerop18
06-08-2006 06:30 PM
BoostedD15B7
12-19-2003 05:35 AM
