AFC Hi Lo settings
Old Apr 19, 2002 | 06:28 PM
vtecsiqt's Avatar
Default AFC Hi Lo settings
Anyone know what the Hi Lo throttle points r suppose to be set at for a 94 b18b. Or any other settings this thing is kind of confusing, also it my seems like it kicks on more now that it is hooked up, running hot or something
Old Apr 19, 2002 | 07:56 PM
rioninja's Avatar
Default Re: AFC Hi Lo settings (vtecsiqt)
The HI and LO settings are used to determine which fuel map to use. If low is set to 20, then under 20% throttle you'll use the low map. If you set the HI to 50, then over 50% it used the HI fuel map. In between 20 and 50%, and it interpolates between the two.
Old Apr 19, 2002 | 08:36 PM
vtecsiqt's Avatar
Default Re: AFC Hi Lo settings (RioNinja)
where should the throttle points be at on a n/a b18b
Old Apr 19, 2002 | 10:31 PM
XforgivenX's Avatar
New User
I'm not sure about an n/a b18b, but my turbo b18c is set at 80% throttle. I would imagine your settings would be a bit lower.
Old Apr 20, 2002 | 08:15 AM
5 Liter Eater's Avatar
You set them to whatever you want. Once you understand what they do you have to judge for yourself. I have mine set at 25% for low and 75% for high.
RTFM
an2ny888
Apr 14, 2005 09:01 AM
vtecsiqt
Jun 25, 2002 09:46 AM
