pvc for charge pipe?
Old Oct 5, 2003 | 01:03 AM
goofball123321's Avatar
Default pvc for charge pipe?
Would pvc pipe be an ok material for charging?
Old Oct 5, 2003 | 01:06 AM
iam7head's Avatar
Default Re: pvc for charge pipe? (goofball123321)
why the heck you want to save a buck or two on your car with all the money spend on it?
dont you hate it when all the ghetto crap trying to do a half-*** job because you want to save yourself some penny?
Old Oct 5, 2003 | 03:36 AM
ross1459's Avatar
PVC will melt VERY FAST
also, it releases poisonous gasses when you heat it up.
order some mandrel bends and weld or clamp them with silicones or radiator hose
Old Oct 5, 2003 | 06:23 AM
89dxhunchback's Avatar
Default Re: (ross1459)
My personal deal with PVC was great. It doesn't melt ( schuale 40 ), and poisonous gas stuff is BS ( gasonline is poisonous too, as well as propaine, and alcoy ).
With my "hot air" motor, the pvc cement has started to give in in a few places... But I'm thinking if you REALLY gunk them up with PVC cement they will last.
IC piping isn't cheap... $65 for piping and another $50 for clamps and silicone, that's the same amount the starion ICs go for !!! I spent $26 at home depot and had 6ft. of pvc left ( and I had to buy the cement too ).
Its "ok" for a temp deal, but... not for more than a few weeks...
Old Oct 5, 2003 | 06:56 AM
fsp31's Avatar
Default Re: (89dxhunchback)
PVC is excellent for temporary charge pipes. I had PVC charge pipes installed "temporarily" on my daily driver for about 4 months while I built my own FMIC and figured out how I wanted to run the expensive mandrel bent pipes.
If your PVC charge pipes begin to leak, then that is the least of your worries because it means that you ran your charge pipes nearly touching (.5" is enough gap to keep the pvc from burning) the exhaust manifold. Here's a neat little experiment: hold a match to a piece of PVC. It doesn't melt, it *burns*.
Old Oct 5, 2003 | 06:59 AM
Ri5e's Avatar
Default Re: (fsp31)
PVC pipes would be fine if you're running it say from the throttle body to the intercooler. I wouldn't recommend using it near the turbo
Old Oct 5, 2003 | 08:14 PM
thanks for the input guys. But I didn't want to take a chance with fumes so I decided to go with flexible radiator hose instead.
Old Oct 5, 2003 | 08:21 PM
This One's Avatar
Default Re: (goofball123321)
I used it temporarily for when i didn't have my Intercooler yet and wanted to get the car running and needed to drive it. I got on it with low boost and didn't have any problems. The only piece i had used it was where the I/C would typically go.
Seemed to work fine and was cheaper than a piece of piping at the hardware store.
EK FLY
Welding / Fabrication
31
Aug 23, 2005 06:50 PM
joshcivic00
Jul 19, 2005 08:20 PM
Def
Nov 15, 2004 10:45 AM
-Trinitron-
Oct 3, 2003 12:25 PM
adhana2
Jun 28, 2003 11:03 PM
