pump gas dyno numbers
Old Jul 30, 2014 | 05:52 PM
jasoncrashtech's Avatar
Default pump gas dyno numbers
i finished this a while back but i'm not h-t much anymore. details are ....
longblock is a b18c (japan gsr)
stock s80 tranny.
stock head, stock dizzy
01 itr cams w/stock gears
wiseco 9:1:1 pistons (compression 180 psi in each cylinder dry)
eagle rods
acl bearings
arp main studs, arp head studs
eagle oil plugs
no block guard , stock sleeves
peakboost ramhorn manifold
2 bolt 38 mm wastegate
silver surfer garrett turbo (water and oil cooled)
3 inch downpipe and thermal 3 inch exhaust
tial blow off
stock throttle body, skunk intake mani
gt-700 single back door intercooler
rc 750's
aem fuel rail
stock filter but no banjo, replaced with a -6an line.
walbro 255 pump
tuned on neptune w/mac boost controler (pull was at 18 psi)
on 92 octane
stock flywheel
4 puck comp clutch
full race pro-am traction bar
Old Jul 30, 2014 | 06:33 PM
Default Re: pump gas dyno numbers
Old Jul 31, 2014 | 03:37 AM
popwars123's Avatar
Awesome numbers! Is this Shodan's newer billet wheeled version?
Old Jul 31, 2014 | 05:47 AM
dcmatt's Avatar
Very nice lookin powerband there. Very nice setup and not overly complicated. Good ****.
Old Jul 31, 2014 | 06:20 AM
thanks guy's , i bought this turbo from him a few years back so its probably the older version (but im just guessing). the project went on the back burner for a bit.
Old Jul 31, 2014 | 06:50 PM
justYncredible's Avatar
It's wU to the sOLdiEr!
Very very very nice numbers! I have similar setup except I have the victor x and the predator turbo. Getting tuned very soon!
Old Jul 31, 2014 | 07:01 PM
i almost went with a performer x or a victor x also. i still might change in the future. i would like to move on to e85 but i'll drive it as is for now.
Old Jul 31, 2014 | 07:38 PM
i had the blox IM and was making 382whp @15lbs and when i switched to the victor x i hit 460whp @ 18lbs on 93 octane. i had a garrett t3/t4 57 trim .63 ar on my old setup before i dropped a valve at the track.
Old Jul 31, 2014 | 09:09 PM
there is only 1 93 pump where i live and 1 e85 pump also. i've been driving on 93 since i found that station but the dyno was on 92.
Old Jul 31, 2014 | 10:53 PM
2kdrift's Avatar
sweet setup. hows the traction with that bar?
Old Jul 31, 2014 | 11:46 PM
a1320honda's Avatar
This was when the shop was 90+ degrees inside and had been making pulls for over an hour. Everything was so heat soaked. On a cool day or a couple quick pulls it would break 500 easy. And its getting awesome mileage
And its a cast wheel
Old Aug 1, 2014 | 05:50 AM
blackeg's Avatar
the victor really does good work over 7000 rpm i have a nice jump in power from there up attributed to the manifold. just dont go too too big of a tb with it it could loose intake velocity with that darn whale dick sized plenum.
you have one sweet setup there, glad you finished it up after it got back burnered for a while
Old Aug 1, 2014 | 09:12 AM
takes the problem of wheel hop out completely. the car either slings forward or looses traction lol. the front torque mount makes more vibration for sure but it can be removed easy.
Old Aug 1, 2014 | 09:14 AM
thanks for tuning it up and recommending neptune steve
Old Aug 1, 2014 | 09:19 AM
i would like to change mainly because i'm sick of the manifold lol. i wouldn't change the throttle body.
thank you
roll8221
Nov 4, 2015 07:11 PM
D-Rob
Aug 30, 2011 06:16 PM
juanb
Dec 18, 2006 11:12 PM
b18c5GT2871R
Jan 19, 2006 04:03 PM
Universal Magnetic
Sep 29, 2004 06:54 PM
