#projectek dyno video
Old Aug 1, 2014 | 12:25 PM
DLB1994's Avatar
Default #projectek dyno video
H23a1 non-vtec
JE 88mm bore k20 pistons 9:1 comp
with a 0.040 thickness custom Cometic headgasket
Custom very large Crower Cams grind to my specs
H22 tranny with drag spool
T4/T67
lovefab sidewinder
44mm wastegate 14psi spring
4inch core intercooler
3inch sidepipe
hondata p06 S200
MSD setup
1000cc 55psi at rail
2 255lph intank pumps custom made -10 feed -8 return
The dyno sheet on wastegate spring 14psi with some creep pump gas everyday power.. Look at the powerband!!!!!!!!!!!!!! non-vtec H reving to the moon! 8400rpms non vtec
Dyno video at 25psi on c16 , turbo needs a rebuild before i turn it up anymore ill post high boost number at a later date..
DLB1994
Jul 8, 2014 02:48 PM
19slocivic97
May 23, 2009 04:32 PM
19slocivic97
Apr 2, 2009 06:38 AM
DLB1994
Nov 3, 2004 12:56 PM
DLB1994
Oct 20, 2004 12:23 PM
