Pulled my Distributor out...
Old Mar 23, 2009 | 02:32 PM
PhantomX's Avatar
Default Pulled my Distributor out...
Pulled my distributor to swap out the ignition coil but then i noticed that the two bottom screws that held my dizzy were kinda loose and was leakin oil......could this damage my dizzy?
Also Im having a hard time removing the rotor... anytipz? (already took out rotor screw)
Old Mar 23, 2009 | 05:46 PM
stockb18c's Avatar
Default Re: Pulled my Distributor out...
pb blaster and some hope
Old Mar 24, 2009 | 04:42 AM
TurboK's Avatar
A new ''O'' ring and you'll be fine.
Old Mar 24, 2009 | 05:34 AM
vietjdmboi's Avatar
Use some channel locks to yank off the rotor.
Old Mar 24, 2009 | 06:04 AM
TurboChurch's Avatar
PB Blaster and let it sit for a day. Then tap on it lightly with a small hammer to loosen it. Try twisting it clockwise to counterclockwise by hand before resorting to visegrips and such. Last resort and its not coming off, dremel with cutoff wheel and grind it off, just go slow so you dont cut the shaft that it slides onto.
blaze the chemi
Oct 20, 2005 12:02 PM
d16rice
12
Apr 3, 2005 06:09 PM
jerseydevil
Jul 25, 2004 01:19 PM
Rory Breaker
Mar 3, 2003 02:25 PM
blackls
Jul 5, 2001 07:31 PM
