Distributor King dizzy, how to remove rotor??
Old Jul 23, 2004 | 04:09 PM
jerseydevil's Avatar
Default Distributor King dizzy, how to remove rotor??
I just got a distributor king dizzy for my 94 gsr. I pulled the cap on it and noticed there is no retaining screw in the rotor like on my oem rotor. What is holding this puppy on there? I hope it's not just a press fit, as in just snug on the shaft. Especially with that crap that was going on with itr dizzy and the rotor seazing the distributor and intake cam.
Old Jul 23, 2004 | 04:10 PM
spaceman's Avatar
Default Re: Distributor King dizzy, how to remove rotor?? (jerseydevil)
after you take out the set screw then it should come off..not sure about yours
Old Jul 23, 2004 | 04:18 PM
That's my point, there is not set screw, not even a hole for one.
Old Jul 23, 2004 | 04:19 PM
spaceman's Avatar
Default Re: (jerseydevil)
wierd..maybe someone else can help you
Old Jul 23, 2004 | 04:23 PM
I don't have the unit right in front of me, but I believe it was a td44u unit. I planned on installing it this weekend. I have a new cap and rotor on my old unit (ignitor went) which I could swap out, but I'm not sure how to get this rotor off, and if I even need to worry about it.
Old Jul 23, 2004 | 05:15 PM
-faded-'s Avatar
have you tried giving a quick turn of the key to spin the rotor to look for the screw?
Old Jul 23, 2004 | 05:33 PM
I can turn her by hand, it's not in the car yet
I'm tellin ya, there's no screw in there.
Old Jul 24, 2004 | 04:55 AM
bump
Old Jul 24, 2004 | 08:07 AM
spaceman's Avatar
did you get the right parts?
Old Jul 24, 2004 | 06:02 PM
It's right for the engine according to there website. The dizzy looks identical to the oem one except for the rotor.
Old Jul 25, 2004 | 05:14 AM
Rod.'s Avatar
i had the same problem........you have to pull on the rotor and it will come off
there is no screw
Old Jul 25, 2004 | 06:30 AM
spaceman's Avatar
Default Re: (redturbocivic)
that doesnt sound like a good design..you just pull it off?
Old Jul 25, 2004 | 07:53 AM
Rod.'s Avatar
Default Re: (spaceman)
i thought the same thing. Someone told me the same thing and I did it to my distributor king dizzy. There is no screw at all
Old Jul 25, 2004 | 01:02 PM
kur0ryu's Avatar
yup I have a DK TD44U, and the rotor just pulls right off, no screw. I've questioned this myself, but it seems to run ok on mine. Rotor doesn't look as nice as an OEM one though.
Old Jul 25, 2004 | 01:07 PM
spaceman's Avatar
Default Re: (kur0ryu)
the distributor king distributors are oem arnt they?..i guess if it works then its all good right
Old Jul 25, 2004 | 01:16 PM
kur0ryu's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spaceman &raquo;</TD></TR><TR><TD CLASS="quote">the distributor king distributors are oem arnt they?..i guess if it works then its all good right</TD></TR></TABLE>
Nope, not oem, I have an oem and a DK, and the DK looks a little bigger, casting isnt as nice, internals don't look exactly the same, but it does the job, and it's still built pretty well. Also when I tested ohms on the internal sensors, they don't meet oem spec for resistance compared to the haynes manual. Still beats paying 800.00+ for a brand new dizzy from honda.
Old Jul 25, 2004 | 01:19 PM
kur0ryu's Avatar
Another gripe is I also had to replace the cam key on my distributor king dizzy with one off my oem dizzys. the original one that came with the dizzy shattered pretty easily when I mistakenly installed it 180 degrees out of phase. Never had that happen with an OEM, but I always check the phase now!!!
twentyhurtz
Dec 24, 2009 04:07 PM
zairas
Oct 25, 2009 10:37 PM
Truman001
May 30, 2006 06:07 PM
vtec.dc2
Aug 24, 2002 11:51 AM
blackls
Jul 5, 2001 07:31 PM
