PSI question
Old Mar 28, 2009 | 05:24 PM
93egSLEEPER's Avatar
Default PSI question
Hey H-T I am new to the boosted portion of honda motors. I have had 3 different swaps in my EJ1 and just built a motor for boost and got it running and boosted a lil bit over a month ago. I am currently running with a 10.15 spring in a tial 38mm WG and when it was tuned at 9.5psi making 306whp. I am looking to bump up the pressure to maybe 12psi but possibly more. my question is what is safe to run on a gsr w/ ls pistons, crank and rods, all arp fasteners with a t3/t04e .54 trim turbo? i would like to get as close to 350whp as possible and still be safe. i have read around on the forum alot and 12psi seems to be my point where i should stop. thanks for the input.
Old Mar 28, 2009 | 09:18 PM
E85B18's Avatar
Default Re: PSI question
12 psi will be ok with your lower compression as long as you get a good tune. Many people are running 500whp on stock sleeves, I wouldnt do it but others are. I think 350 is a good number to stop at but you are going to be pushin OEM honda pistons at that point
Old Mar 28, 2009 | 09:19 PM
E85B18's Avatar
Maybe get a block guard?? Some people dont like them but i think it can only help
Old Mar 28, 2009 | 09:31 PM
turbociv910's Avatar
Dont get a block guard.
How do you run lower boost than your waste gate spring?
Ive had a LS with arp head studs and stock bottom end on 17 psi still going strong.
Old Mar 28, 2009 | 09:43 PM
blinx9900's Avatar
I smell an Autometer boost gauge or a boost leak...
Old Mar 28, 2009 | 09:52 PM
Or the Glow Shift boost gauges.
Laugh every time.
Old Mar 29, 2009 | 04:04 AM
Silva Bullit DC4's Avatar
He may be running a boost reference source, other than a vacuum source, and he may be seeing a psi drop from the IC. My 10.5 spring did the same thing, 9.5 psi.
OP, dont base your goal on psi alone, your tuner will use whatever psi your setup will take to make 350 whp. Just make sure the tune is spot-on.
Old Apr 1, 2009 | 04:10 PM
weird you say that cause i have an autometer gauge. no boost leaks i have checked.
as said above about the IC i have never heard of that but nice to know. I am using a vaccuum source strait off the IM for the gauge. When i run it open downpipe it registers like .5 psi more boost.
I have an amazing tuner... he has run a y8 vitara setup on 29psi for 2 years now no problems and is at 500whp running 10.3 in the 1/4. Im sure i can run a 14.5 spring and be safe and reach my goals. I just would hate to have it blow as it is my only car and being a college student/baseball player money is tough to come by. thanks for the input
Old Apr 5, 2009 | 02:37 PM
bada9's Avatar
i had a stock block h22 and made 415whp @ 15psi and it ran strong for over a year until it was stolen
Old Apr 5, 2009 | 03:53 PM
Romo Pyro's Avatar
Originally Posted by 93egSLEEPER
all arp fasteners
: please elaborate
Do you have arp head studs, rod bolts, main studs etc? what do you mean "all arp fastners?
If it were my car and I wanted a reliable boosted dd, I would invest on some rods,pistons, rod bearings.
vtak2nr
Jul 7, 2011 09:36 AM
93egSLEEPER
Mar 29, 2009 12:42 AM
93egSLEEPER
Mar 28, 2009 05:35 PM
turboludeARG
Jan 4, 2006 08:08 AM
LilCivic04
May 31, 2005 09:12 AM
