Psi keeps getting lower on d16z6
Old Mar 9, 2012 | 04:40 PM
  #26
boostedz6bassma's Avatar
Default Re: Psi keeps getting lower on d16z6
changed waste gate AND turbo and itll barley push 5psi......
im taking it i have a boost leak and i cant find it
Old Mar 9, 2012 | 05:24 PM
  #27
NonovUrbizniz's Avatar
Loved
Why would you change the wastegate and turbo?
You have a crappy ebay ramhorn. The wastegate placement likely sucks and won't allow the waste gate to do it's job without completely screwing up the flow to the point that the turbo stops making enough much less "too much" boost that triggered the wastegate to open in the first place.
get a cheap log manifold... buy the one in my for sale thread. It's a nice spoolin performance number... Even an ebay log would be better than a crap ebay ramhorn.
Ramhorns are really for track cars IMO. Miniram at most for a street car. logs build the boost much earlier but don't flow quite as well up high... big woop.. makes for a flatter wider torque curve which is worth it's weight in gold in a street car.
Old Mar 9, 2012 | 11:10 PM
  #28
racebum's Avatar
Originally Posted by Shaunathan
this is a perfect example why not to purchase things for your car off ebay. Performance Cars is not a cheap hobby and it never will be, if you can't afford to buy decent parts from reputable sources, i suggest either finding a new hobby or you'll find yourself fixing things than actually driving. Stop Cutting Corners
x2
i just stepped back. said enough was enough
people have to be real about what it is they are doing. i stepped back not because i dislike racing, but because i'm now a home owner, have business expenses and can't blow all my cash like i did at age 21-26 at the track.
Old Mar 10, 2012 | 04:47 AM
  #29
Turbo-LS's Avatar
OP check all areas for leaks and then GO GET THE DAMN THING TUNED !!!!!!
If its pig rich it will fluctuate boost pressure because the exhaust gasses wont be expanding like there supposed to and can cause the boost pressure to jump up and down along with ignition timing not being tuned properly will A blow the motor and B cause the same problem
YET ANOTHER - I'm ruipping around in boost on a base map thred and cant figure out why its not right .
philly10psi
Aug 24, 2011 09:01 AM
XanderTurbo88
Oct 31, 2008 06:01 PM
94dxt
Aug 10, 2003 07:49 AM
Licensed2Spool
May 28, 2002 08:25 PM
