Profec B Setup
Old Apr 22, 2003 | 11:41 AM
incognitoracerr's Avatar
Default Profec B Setup
Can anyone explain how to install the profec b on the greddy sohc turbo kit...I have no idea how to run the hose to what and can't figure it out from their instructions manual....
I want to boost out of the 5.5 range....lol
Help me out guys ...what goes to what...
Old Apr 22, 2003 | 11:50 AM
b18bturbo's Avatar
Default Re: Profec B Setup (incognitoracerr)
1 step is back of profec b is selectiong which type of wg you have
set the dip switched to what ever wg based on the manual
2nd step
run hose from intake mani to the back of the profec
3rd step
you have the stepper motor
one side is inlet and one side is outlet
outlet goes to top port of wg or on internal wg side port
the inlet port on the stepper motor goes to intake mani or direct to the turbo inlet some turbos have a nipple there
Old Apr 22, 2003 | 12:21 PM
Default Re: Profec B Setup (b18bturbo)
Hey man thanks...I just set it up and it works...I very much appreciate it...I used a t fitting for he wastegate side because as you know there is already a blue vacumm hose on the wastegate so i used the t there to make room for outlet to go there...hope that won't harm anything
b18bturbo's Avatar
should be fine..
b18vtec
Nov 24, 2008 08:31 AM
sirtef9
Dec 22, 2007 10:13 AM
turbocivichb
Nov 2, 2003 08:25 PM
buddha429
Jan 1, 2003 10:18 PM
