problems using blue box and stock injectors?
Old Mar 26, 2004 | 05:32 AM
dwn4cause's Avatar
Default problems using blue box and stock injectors?
I am on a budget and only plan on boosting 5psi.. is there a problem with using the stock injectors with the blue box.. i beielve the blue box just makes the pluses longer, but i heard the blue box runs rich.. so with small injectors would it run a bit leaner..thanks for all your help.. i tired to search but noghting came up
Old Mar 26, 2004 | 06:57 AM
mchuang's Avatar
Default Re: problems using blue box and stock injectors? (dwn4cause)
That greddy blue box sucks ****. Had a similar setup at the shop but with took out the blue box and put in an fmu and a fuel pump and just tuned it on afc.
You can get a used fmu for about 80 bucks inline pump about 80 bucks.
Old Mar 26, 2004 | 09:28 AM
dwn4cause's Avatar
anyone else?? so a fmu, fuel pump, check valves, with stock ecu and stock injectors is better than blue box, fuel pump, stock injectors, and stock ecu.. any help would be apperciated..
Old Mar 28, 2004 | 07:37 PM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwn4cause &raquo;</TD></TR><TR><TD CLASS="quote">anyone else?? so a fmu, fuel pump, check valves, with stock ecu and stock injectors is better than blue box, fuel pump, stock injectors, and stock ecu.. any help would be apperciated..</TD></TR></TABLE>
**** what that guy said. I'm running the blue box at 7 psi on my greddy turbo D16Y8 and it runs fine; a little boggy at partial-throttle boost, but what do you expect for $50? It runs fine at WOT or when racing (fine=12.5:1 AF ratio under boost) .
uninformed blue box haters
Old Mar 29, 2004 | 06:32 AM
FuriousGeorge's Avatar
Default Re: problems using blue box and stock injectors? (boostincoupe)
I agree. I am running the blue box at 8psi on my Y7 with no problems. I think the issue is that at 5 psi the box causes you to run righ, but at 7-8 the ratio looks just right. Check this thread out for some results (not my car, but similar).
http://turbod16.com/viewtopic....e+box
lDanny
Mar 30, 2005 02:14 PM
kranked91dx
Nov 20, 2003 05:03 PM
skierGT
Oct 8, 2003 10:49 AM
Hybrid
Feb 21, 2002 03:41 PM
SiBirdie
Sep 28, 2001 09:31 PM
