Problems with turbo D16Y8
Old May 19, 2015 | 11:02 PM
hellboy21's Avatar
Default Problems with turbo D16Y8
ej8 own a stock internal turbo engine is completely 10psi factory alone will amount a turbocharged Subaru WRX STI and 07 and have a drawback but the turbo connected in low smokes The car is not smoked, has neither nozzles or computer, nothing happens engine, compression is good, accelerates and responds only to lansa white smoke from the exhaust, turbo works with External wastegate, and spring 10 pounds, the turbo uses two cooling water hoses that are not connected, only oil and return Everything works well, the oil pressure with cold engine is 95-100 psi stays hot at 50 psi 120 psi 7000rpm no oil leak, today full throttle and third spat A Union curb, I saw it was that and I take you home in the probe caminio full throttle so meti four changes 7k rpm and 0 smoke white because I connected the turbo strip white exhaust smoke and Offline is not this the tube that admission will not release the car smoke, if the only thing that changes is that no air under pressure to the engine.
this is the engine
Old May 19, 2015 | 11:08 PM
DC4KiD's Avatar
Default Re: Problems with turbo D16Y8
Old May 20, 2015 | 02:21 AM
NotARaCist's Avatar
I never narc'd on nobody!
Old May 20, 2015 | 02:39 AM
ss_zoidberg's Avatar
this is the engine
Where to start
Old May 20, 2015 | 04:06 AM
Bently_Coop's Avatar
Steve at Heart
Hamza's twin
Inb4notgdd
Old May 20, 2015 | 04:53 AM
Pinja's Avatar
Drunk Wagon Pilot
How the **** did you get a driver's license OP
Old May 20, 2015 | 05:27 AM
GraphiteAcc0rd's Avatar
Old May 20, 2015 | 08:08 AM
2LEM1's Avatar
I like to party
Community Builder
Community Influencer
What's funny is I think Google translate spit that out.
Old May 20, 2015 | 08:42 AM
pogeeboy27's Avatar
I'm not even going to attempt to read this. Good luck OP.
Old May 20, 2015 | 09:12 AM
Full_Tilt's Avatar
Damn. Well, Im going to try to be helpful.
White smoke is normally burning coolant. This means you have a blown headgasket. To be sure you need to do a compression leakdown test. Google it.
What are you using for tuning? Is your ECU chipped? Stock injectors?
Old May 20, 2015 | 09:26 AM
hellboy21's Avatar
Ok'm from panama English is very basic, use a translator apologize for as I write, just ask help understanding how to solve the problem not be a joke for not knowing English, because Just as it is difficult for you the Spanish for us English. manufactures injectors, without chip factory ecu.
Old May 20, 2015 | 09:32 AM
Full_Tilt's Avatar
Well there is your problem.
Old May 20, 2015 | 09:38 AM
hellboy21's Avatar
As far as I have understood if the turbo is not connected the car pulls no white smoke, once connected with the admission and emits white smoke that's what I do not understand, if broken rings used Should always smoke and just makes the turbo connected not consume water only thing unusual is that the turbo has no water hoses connected, Compression is good and the car was measured and not blowing air through the valve cover and without the turbo accelerates to 7k and the car is even and smokeless, and not mixing
Old May 20, 2015 | 09:46 AM
hellboy21's Avatar
ok you say that because I have white smokes car manufactures injectors and ECU factory? But because the turbo switch stops pulling the car white smoke?
Old May 20, 2015 | 10:21 AM
JDMarv's Avatar
youre on factory ecu and injectors? thats a no-no right there
Old May 20, 2015 | 03:32 PM
Xanthias's Avatar
Thank god I was trying so hard to understand wtf he was saying only to scroll down to some nice reassurance.
Old May 20, 2015 | 04:33 PM
h22-eg-hatch's Avatar
damn auto correct lol
i think the turbo is no good
i understood that his car smokes only when turbo is connected
no turbo=no smoke
turbo=smoke
seals in turbo are most likely bad
Old May 20, 2015 | 07:46 PM
hellboy21's Avatar
And the problem was detected retainer admission of this faulty turbo and oil to boot admission so white smoke.
Old May 20, 2015 | 08:38 PM
riceball777's Avatar
I'm sorry but nothing you are typing makes any sense at all. You need to find someone that can type in correct English so we can understand so we can help you.
Old May 20, 2015 | 10:04 PM
NotARaCist's Avatar
Or try to find a forum in your native language. As much as I hate to directly turn people away from H-T, it's obvious that the language barrier is going to be a HUGE problem here.
lookout22
May 17, 2009 07:37 PM
norcalbayboy
May 5, 2008 11:20 PM
TnC
Mar 30, 2008 01:57 PM
eky2k
Feb 27, 2004 11:45 PM
4gvtec
Apr 4, 2002 05:05 PM
