Problems starting car with afc hack
Old Dec 29, 2002 | 11:16 AM
93teg's Avatar
Default Problems starting car with afc hack
Ever since I installed the afc hack and the dsm 450cc injectors I have had problems starting the car. I never had problems with the greddy blue box, the car would start right up. To get the car to start easier I need to completely lean out the 1000rpm to -50, and even then then it doesnt start too great.
Old Dec 29, 2002 | 11:45 AM
Jared's Avatar
Default Re: Problems starting car with afc hack (93teg)
is your fuel pressure too high?
Old Dec 29, 2002 | 01:55 PM
rioninja's Avatar
set your low throttle 1000rpm to -25% instead of -40. should smooth things up.
Old Dec 29, 2002 | 02:15 PM
rjardy's Avatar
Default Re: Problems starting car with afc hack (RioNinja)
adding more fuel may work only if he is sure that its lean
Rob
Old Dec 30, 2002 | 12:15 AM
93teg's Avatar
Well I dont think its my fuel pressure. because I have the stock regulator, at idle im at about 42 psi. My wires, coil, cap, rotor, ignitor, and spark plugs have less than 7000 miles. I dont think more fuel will help, because my car starts better when i lean it out. I dont even think my car would idle with a -25 setting, that seems way too rich to me...
[Modified by 93teg, 9:17 AM 12/30/2002]
Old Dec 30, 2002 | 04:21 AM
civicwagonman's Avatar
42? I think you're regulator isn't working. should be about 35psi with vaccum on the regulator. anyone else?
Old Dec 30, 2002 | 05:17 AM
boostin b16's Avatar
Default Re: Problems starting car with afc hack (civicwagonman)
I think the fuel pressure should be in the 35 psi range, but i am not too sure. On the afc, make sure that in the seetings section that it is set to "pressure" and "06" in and "06" out. that could be the problem.
good luck
Old Dec 30, 2002 | 09:38 PM
Johnyquest's Avatar
Default Re: Problems starting car with afc hack (boostin b16)
yeah, sensor settings were my first problem.. make sure you check that. I set all my settings to -35 across the board or was it 36 i think but either way the 450's start fine for me... A little hiccup here and there but they are big. hack = cool (once i bold the friggen charger up) : )
Old Dec 30, 2002 | 10:24 PM
J2turbo21's Avatar
i know this is very stupid,but what is a afc hack?Also what is SMC?I hear both these but i dont have a clue what it is.
Old Dec 30, 2002 | 10:41 PM
Daniel's Avatar
Default Re: Problems starting car with afc hack (J2turbo21)
do a search, man. It's been covered many a time. . . .
turbod16y7vtec
Dec 5, 2004 08:39 AM
PM-Performance
Jan 30, 2004 01:16 AM
BoostedD15B7
Nov 22, 2003 05:45 AM
GOLDBERG
Apr 3, 2003 08:18 PM
Johnyquest
Dec 29, 2002 03:26 PM
