450CC INJECTORS. Problems starting car.
Old Nov 20, 2003 | 04:07 PM
BoostedD15B7's Avatar
Default 450CC INJECTORS. Problems starting car.
Just put some 450cc dsm on my sohc and safc and a 255 fuel pump(intank). I have the fuel way down at idle. Its at -41 but the car doesnt fire up like it use to. It turns over 10 to 15 times before starting. Once its started it runs great. What would cause this? The only thing i can think of is my fuel pressure. Im running the 255 pump with a stock fuel regulator. Possibly the 255 raised up the fuel pressure to a point where the car doesnt want to start easily. Maybe i need a adjustable and turn the pressure back down to about 38. What do you guys think? I cant think of anything else that might cause this. Oh yeah. if i shut the car off after driving it and get back in within 10 minutes or so, it starts right up. Just doesnt like cold starts.
Old Nov 20, 2003 | 04:59 PM
MiraiZ's Avatar
Default Re: 450CC INJECTORS. Problems starting car. (BoostedD15B7)
are you letting the fule pump prime?
Old Nov 20, 2003 | 06:48 PM
Jonny Black's Avatar
mine did the same thing..its getting flooded in the morn on the prim..I have a fuel cut off switch which I keep off until after the prime..then turn it on turn the key..and boom two turns and it starts right up..pretty common with the 450s really.
Old Nov 20, 2003 | 08:12 PM
m R g S r's Avatar
Default Re: 450CC INJECTORS. Problems starting car. (Jonny Black)
I have a b18 so I don't know if it's any different, but basically same setup, intakn, hack and 450's and my car actually starts fatser now then it did before.
Old Nov 20, 2003 | 09:28 PM
BoostedH23a1's Avatar
Default Re: 450CC INJECTORS. Problems starting car. (m R g S r)
tune a lean lean lean idle... but not dumbass lean.. u know what i mean.
Old Nov 20, 2003 | 09:47 PM
teg969's Avatar
Default Re: 450CC INJECTORS. Problems starting car. (BoostedH23a1)
same for me, i have talon 450 injector on my b18b, and its starts liek **** but only when hot, when cold it starts up great, i though maybe this was caused by my retarded timming, i m not running hondata or anything, my fuel control is made by apexi VAFC, so the timming was retarded manually, woundered maybe thats my problem
Old Nov 21, 2003 | 03:14 AM
Default Re: 450CC INJECTORS. Problems starting car. (teg969)
yes im letting the pump prime. Would lowering the fuel pressure fix it?
Old Nov 21, 2003 | 03:24 AM
Jockobo's Avatar
when i have my fuel pressure up to 45 psi instead of 40 psi its a big difference in starting the car.
Old Nov 22, 2003 | 03:11 AM
Default Re: 450CC INJECTORS. Problems starting car. (Jockobo)
is it a 1.5 or 1.6 sohc motor?
Old Nov 22, 2003 | 05:27 AM
Dr Honda's Avatar
I run 450 DSM's and my car starts and idles perfect... hot , cold... whenever. But I used Crome to make a chip. It seems to be a common prob with the AFC hack.
Old Nov 22, 2003 | 05:45 AM
b16ahybrid's Avatar
d15b7 = 1.5ltr
dkennedy1
May 13, 2017 04:38 PM
JmurGSR98
May 20, 2012 05:26 PM
clemsoncb7
Dec 22, 2006 08:32 PM
Javier23
Dec 18, 2003 10:01 AM
Rob Dizzle
Apr 21, 2003 11:05 PM
