Problem w/ boost
Old Jun 9, 2004 | 10:27 AM
tegedrex's Avatar
Default Problem w/ boost
I cant seem to get past 3lbs on just the wg, if I uninstall the hose to wg it builds nicely, or if I put a T in between the lines same thing builds up. The springs in suppose to be .5 bar. I checked all hoses, and everything seems fine. I run the hose from the bottom nipple of the wg to the compressor housing nipple.(is this right?)
Old Jun 9, 2004 | 02:20 PM
tegedrex's Avatar
Default Re: Problem w/ boost (tegedrex)
bump
Old Jun 9, 2004 | 02:24 PM
Rod.'s Avatar
seem like you having the same problem as jdmh22hatch on here
Old Jun 9, 2004 | 04:59 PM
tegedrex's Avatar
Default Re: Problem w/ boost (redturbocivic)
But unlike him when I pull the WG line off it keeps on building boost.
Old Jun 9, 2004 | 11:26 PM
tegedrex's Avatar
someone???
Old Jun 10, 2004 | 08:15 AM
95GSRTT
Guest
Posts: n/a
Umm if you unbolt the wastegate and it works. Its your wastagate. Get a new one and make sure its sealed probably. End of problem.
Old Jun 10, 2004 | 08:21 AM
turbo89civicb18hatch's Avatar
wat kind of wastegate is it, i would get a 38mm tial they are very acurate. also were do u have the vacume line to, u may not have a strong enough vacume, t off the brake booster line and it should work if your wastegate is good.
Old Jun 10, 2004 | 11:22 AM
tegedrex's Avatar
Default Re: (turbo89civicb18hatch)
Its a 40mm Tial, I have the line going from the wg to the turbo comp. housing.
94integragsr
May 9, 2006 10:18 AM
PooOnMyShoe942
Sep 30, 2005 04:50 PM
yellow blur
Oct 7, 2004 06:22 AM
jwcardy
Sep 5, 2004 02:06 PM
gdrum
Feb 16, 2004 10:21 PM
