injector questions
Old Oct 22, 2005 | 12:33 PM
hatchbackjdm's Avatar
Default injector questions
i know that everyone runs the dsm 450s, but is it possible to run toyota injectors? if so i have a set of injectors from my 4agze (i think they are 310cc) i will be running 8 psi on stock ls bottom end, will these be enough? also i will be running an apexi safc, i dont know if i will need a different map sens so that it will know im boosting or not. any help is appreciated greatly
Old Oct 22, 2005 | 12:42 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: injector questions (hatchbackjdm)
check the resistence, if they are 12-13 ohm, you dont need a resisrot box, if they are 2-3 ohm you need a resistor box. i dont like boosting with the afc. i would do some other form of engine management.
Old Oct 22, 2005 | 12:47 PM
Default Re: injector questions (boostedcivicsir)
like what? dont have money to do alot and already have the afc from my last car
Old Oct 22, 2005 | 01:01 PM
up!!!!!!!! anyone have any insight on the topic?
Old Oct 22, 2005 | 01:14 PM
Mr. Badwrench
Default Re: (hatchbackjdm)
spend a little now or alot later......there are many th choose from, hondata, crome, uber, neptune, pick one. i know it is kind of hard to do it on a budget, but i would trust stock injectors with an fmu before i trust an afc, but thats just me.
Old Oct 22, 2005 | 01:22 PM
use something like this,
http://cgi.ebay.com/ebaymotors...QrdZ1
and my stock injectors will be enough?
Old Oct 22, 2005 | 02:01 PM
bump. is there anyone who knows for sure about the toyota injectors and or the fmu and stockers?
Old Oct 22, 2005 | 02:38 PM
_gurusan_'s Avatar
don't skimp on your fuel system.
I suggest buying a walbro 255lph fuel pump and some brand new tunertoys 450cc injectors.
It will run about 300 total but you won't have to ghetto rig anything and you're fuel system will be strong enough to reliably support a turbo system.
Old Oct 22, 2005 | 02:43 PM
Mr. Badwrench
Default Re: (_gurusan_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _gurusan_ &raquo;</TD></TR><TR><TD CLASS="quote">don't skimp on your fuel system.
this is what we are trying to say, if you are into it that far, you can spend a little, then nuke the engine, and pay alot more. the 310's and your afc will not be enough for your fueling needs. period. you need to do an fmu like the one you have or do it the right way with atleast 450's and some engine management.
Old Oct 22, 2005 | 03:46 PM
Default Re: (boostedcivicsir)
cool well i appreciate the advice
jdmboy94
Oct 13, 2010 02:43 PM
Integra808
Jul 31, 2003 10:38 PM
T3T495GSR
Apr 4, 2003 11:05 AM
legendboy
Aug 19, 2002 01:38 PM
