Problem! Need suggestions.....
Old Aug 28, 2002 | 10:53 PM
  #51
highmilehatch's Avatar
Default Re: Problem! Need suggestions..... (BG Boost)
Just a shot in the dark, but maybe the bottom of your block is warped causing the oil pan to not seat properly, but then again you said you bought the block new from the dealer.
Old Aug 29, 2002 | 03:59 AM
  #52
rjardy's Avatar
Default Re: Problem! Need suggestions..... (turboeg)
I think that the block it self is tob big to warp, if it did it would crack. Just my thought on it.
Rob
Old Aug 29, 2002 | 04:44 AM
  #53
CalvitoSol's Avatar
Default Re: Problem! Need suggestions..... (rjardy)
this is sorta ot and i don't have any suggestions but i'm a newbie and figured that since we're in the topic of oil leaks, i figured i'd ask a question. are oil leaks common on fi b-series engines? i have a completely stock b16a3(delsol) and planning on running about 8-9 lbs daily and 12 on track days w/ a t3/t4 hybrid. i'm also gonna run an oil cooler. so, wouldn't this also cause a few problems w/ oil pressure? will encounter similar problems or is this on rebuilt/heavily modified engines?
Old Aug 29, 2002 | 06:35 AM
  #54
95GS-R's Avatar
Smaller oil filter, less volume..guess that causes more pressure?
Borrowing from the Ideal Gas Law:
PV = nRT
Pressure and Volume are inversely related, therefore when you have less volume you will have more pressure, all other things staying the same.
Old Aug 29, 2002 | 07:03 AM
  #55
glagola1's Avatar
Default Re: Problem! Need suggestions..... (95GS-R)
Sometimes I feel like I'm actually losing braincells when I visit this site.
Old Aug 29, 2002 | 08:31 AM
  #56
1fstevo's Avatar
New User
Default Re: Problem! Need suggestions..... (glagola1)
if volume increase then pressure decrease then should I say add a oil cooler??
Old Aug 29, 2002 | 09:16 AM
  #57
civicwagonman's Avatar
Default Re: Problem! Need suggestions..... ([Evo]Hybrid)
The whole problem here seems to be crankcase pressure buildup. i've never seen a factory turbo car that didn't have a pvc valve. its designed to keep excess pressure off your gaskets so you don't blow them out. its a one way valve so boost isn't going to get into your motor back thru it unless its bad. you need the pvc in the factory location and then take your valve cover vent and route it to the pipe in between your air filter and turbo intake, that way the pvc relieves pressure under normal driving, and when you boost the turbo will help relieve the pressure thru the valve cover vent. alot of drag cars that aren't turbo have ports in the exhaust that use the pressure to suck out the crankcase pressure, which actually helps the efficiency of the motor.
Old Aug 29, 2002 | 09:31 AM
  #58
Ri5e's Avatar
Default Re: Problem! Need suggestions..... (civicwagonman)
Hmm...sounds like a good idea.
Why not connect two catch cans? One that connects in between the PCV and the Intake manifold so when under VACUUM it'll filter out the oil vapors and still retain the PCV system to help relieve excess pressure.
And another on that connects in between the valve breather and the Turbo Inlet pipe. When you are in BOOST the other catch can "disables" (Because the PCV will close when it sees positive pressure in the manifold). The turbo will help suck the positive pressure from the crank case in boost so no more oil pan gasket blowing. And you don't have to worry about oil getting into the turbo with the catch can there.
Get what I'm saying?
Old Aug 29, 2002 | 01:28 PM
  #59
1fstevo's Avatar
New User
The pcv valve is way too small to vent anything under high boost. Crank pressure is realized under high rpm and heavy load. It should go out of the block not the head if it properly ventilated. On stock mode, manifold is sucking the vapor out and put fresh air through the breather. After you add turbo system, the rule change a bit. Before there is no boost, now there is. Under boost, with pcv connect to the vaccuam source will yield little or no ventilation. It's enough pressure in there that it should exit out where the low pressure is. With a pcv intact even without vaccuam source may hinder venting. Look at the valve, you think anything larger then stock pressure will get out with a ball stuck in there? I went open loop with no pcv and a filter on the breather. Black box connect with a hose which run directly to a catchcan with another filter on top. Try blow in the valve see if you will turn blue.
[Modified by [Evo]Hybrid, 10:31 PM 8/29/2002]
Old Aug 29, 2002 | 01:54 PM
  #60
niedejb's Avatar
The PCV valve only opens with vacuum in the manifold. I tried leaving it in with the catch can (with the exit being a mini filter) and it never opened. Had to take the PCV valve out to get the can to see any flow.
Old Aug 29, 2002 | 08:34 PM
  #61
Ri5e's Avatar
Default Re: Problem! Need suggestions..... (niedejb)
hmm...maybe drill and put like 3 more breather holes on the valve cover maybe that' will help? Release all the pressure.
Old Aug 30, 2002 | 12:48 AM
  #62
1fstevo's Avatar
New User
haha, i would rather do that to the block so more vapor can be vented.
JDMob
Jan 26, 2020 11:17 AM
Gfunk176
Mar 2, 2007 09:13 PM
Teglessb18
Oct 21, 2005 03:06 PM
hybrid_vtec
Dec 27, 2004 12:31 PM
mike1114
Mar 21, 2004 12:55 AM
